Freud FT1700 VCE problem. - Router Forums
post #1 of 3 (permalink) Old 07-07-2012, 06:20 PM Thread Starter
First Name: Al
Default Freud FT1700 VCE problem.
Hi members. I have had the fixed body component of this kit attached to router FT1700 VCE and mounted in a table for about a year, working well. Recently when using the above table device to raise the router it rises about one inch and then binds. I find I am having to support underneath the router body to help the router to rise smoothly. My first instinct was to lubricate the barrel of the fixed base but I think I read a comment that lubricants and wood routers don't go well together, so I am reluctant to use a teflon, graphite or other based lubricant on the barrel of the router to try to help. Any suggestions. Oldrusty.
oldrusty is offline
post #2 of 3 (permalink) Old 07-07-2012, 07:24 PM
Hi Rusty - After a year under the table, I suggest you seperate the motor and base and clean it up really well. Dry lubricants are OK, I used spray graphite on mine but wax, teflon lube or even parrafin should work OK. You may also need to get to the lead screw and clean it. Sounds like it may be binding. Item #12 on your parts list is the depth support adjusting screw. Looks like it may be a kit or an assembly as the screw and follower both have the same number. If the body and base are clean and move freely, that would be my next guess. You may also want to give Freud a call as those had a 5 year warranty.
Oh yeah, the Canadian number is 905-670-1025
John Schaben
jschaben is offline
post #3 of 3 (permalink) Old 07-11-2012, 12:50 PM Thread Starter
First Name: Al
Thanks John. I will give your suggestions a try and if they don't solve the problem I'll contact Freud Canada. Thanks again Oldrusty
oldrusty is offline
Freud collet problem. oldrusty General Routing 9 03-21-2012 08:43 PM
Freud FT2000E Problem DannyL General Routing 5 02-06-2012 11:06 AM
Freud FT3000 VCE Table Insert Issue andyk Table-mounted Routing 13 01-05-2011 06:11 AM
Freud FT1700 Router and Guide Bushings dwwilson44 Guide Bushings and Templates 61 09-10-2010 12:18 AM
Freud RT 5000 & 1700 VCE bphillips New Member Introductions 1 07-17-2008 08:22 AM
