Incra Offset Table Top or Woodpecker Offset Table Top - Router Forums
post #1 of 45 (permalink) Old 04-23-2013, 11:52 PM Thread Starter
First Name: Gareth
Default Incra Offset Table Top or Woodpecker Offset Table Top
In my search for a router table, I had been really interested in solid phenolic tops because of the stability of the material. Then I found the Incra LS system and realized that I would need to get an offset router table top or build one. I cannot find anyone that manufactures a solid phenolic offset top.
I'm interested in the Incra 27"x43" offset top or the Woodpecker 32"x53" offset top. Both these are MDF cores with phenolic laminated to both top and bottom. I have wondered how well tops like these hold up to dampness, such as shops located in basements. Do tables of this sort hold up or how common are de-lamination issues?
DoItMyselfToo is offline
post #2 of 45 (permalink) Old 04-24-2013, 07:24 AM
First Name: Duane
My Woodpeckers top has been just fine for 18 years. I has occasionally been in damp enough conditions to rust cast iron tables tops. I personally have neve seen one delaminate. I think the bigger issue is having enough support under to prevent sagging, especially if you are mounting a large 3+HP router under it.
Dmeadows is offline
post #3 of 45 (permalink) Old 04-24-2013, 09:51 AM
Shortslvs's Avatar
First Name: Fred
Have you thought about a de-humidifier? Just mentioning that because if you have enough moister to possibly do damage to that top there are probably other tools suffering. sometimes just keeping a fan running and air moving can be helpful. I know it doesn't answer the question.
I have the incra table, but I live in the high desert
Shortslvs is offline
post #4 of 45 (permalink) Old 04-24-2013, 11:19 AM
Here i go, changing the subject again, but why is your basement damp?
Unless that was just an offhand example?
Damp leads to mould and we now know how serious a health issue mould is.
Anyway that didn't help with your question...
DaninVan is offline
post #5 of 45 (permalink) Old 04-24-2013, 12:19 PM
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Didn't know there were solid phenolic tables available. I thought phenolic was just the special surfacing applied to some substrate.
In any case you could just make up your own table using phenolic covered plywood if you are concerned about the MDF substrate.
cagenuts is offline
post #6 of 45 (permalink) Old 04-24-2013, 03:09 PM
Garyk's Avatar
First Name: Gary
I have a Woodpeckers table top that is also 18 years and it is in good condition. No problems with delamination. An MDF or MDO core is stable and not likely to be affected by moisture in the air unless you soak the material. Solid phenolic is available, you just have to search for a source. I found a company in Greenville SC that sold any color, thickness and etc you would want by looking on the internet. Sorry but I don't remember their name. I can tell you that the Woodpeckers table will be a heck of a lot cheaper. Most companies don't like to sell small quantities of the material unless they have some scrap pieces available.
Garyk is offline
post #7 of 45 (permalink) Old 04-24-2013, 03:59 PM
Big Steve's Avatar
First Name: Steve
I also have the Woodpeckers table for more than a decade. No problems at all.
Steve
Richmond, Virginia
Big Steve is offline
post #8 of 45 (permalink) Old 04-24-2013, 08:18 PM Thread Starter
First Name: Gareth
Dmeadows - thanks for your input. Just looking to get perspective and your 18 years gave plenty. I am planning to install the 3 1/4 horse Porter Cable, so I'll be sure to get some support under it. I've heard this from several sources.
post #9 of 45 (permalink) Old 04-24-2013, 08:20 PM Thread Starter
First Name: Gareth
I have a dehumidifier and run it when needed, which really is not that often. I had heard about delamination issues here and there. I then resolved to get a solid phenolic top but when I settled in an Incra LS, that changed my plans a little.
post #10 of 45 (permalink) Old 04-24-2013, 08:21 PM Thread Starter
First Name: Gareth
No mold here but thanks for thinking of my health.
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
Woodpecker Lift, Bench Dog Table snmhanson Table-mounted Routing 5 08-15-2011 01:47 PM
router table top delroy33 General Routing 18 07-30-2006 05:53 AM
Second Cedar Top Table GoonMan Show N' Tell 7 09-19-2005 11:43 PM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 10:15 PM
