Guide bushing question - Router Forums
post #1 of 9 (permalink) Old 12-03-2013, 02:16 AM Thread Starter
First Name: Bob
Default Guide bushing question
Newbie here, so bear with me as I throw out some questions.
I am looking to buy a Bosch 1181 table and want to know if it is possible to fit guide bushings to the standard insert.
If so, how?
If not, is it possible to fit a different insert?
TIA
Bob
HawaiiBob is offline
post #2 of 9 (permalink) Old 12-03-2013, 08:50 AM
GulfcoastGuy's Avatar
First Name: Patrick
If none of the inserts have the necessary flange you have two options. Get a spare insert set and route the flange on the appropriate one (small part safety practices in full force, keep the meat away from the rapidly spinning, very sharp bit), or make a replacement mounting plate with an integral flange.
Ideas HERE
GCG
___
"I was always afraid of dying. Always. It was my fear that made me learn everything I could about my airplane and my emergency equipment, and kept me flying respectful of my machine and always alert in the cockpit. " - Chuck Yeager
___
http://www.routerforums.com/table-mo...table-saw.html
GulfcoastGuy is offline
post #3 of 9 (permalink) Old 12-03-2013, 09:02 AM
First Name: Patrick
Alternately if the Bosch mounting plate is smaller than, say, the $13 Grizzly plate you could conceivably use the Bosch plate as a pattern and trim the Grizzly plate to size; drill and tap as need to match the Bosch plate's functionality. The only possible hitch may be irregularities on the underside of the Grizzly plate. I use one but I'm not home so I can't check right now.
GCG
___
___
post #4 of 9 (permalink) Old 12-03-2013, 10:51 AM Thread Starter
First Name: Bob
Thanks mate.
Being a newbie to this stuff, I am not even sure what I need this for, but maybe by the time I do, it will be time again to upgrade my table to something that does not need modifying.
post #5 of 9 (permalink) Old 12-03-2013, 11:11 AM
walowan's Avatar
First Name: Michael
I have never used guide bushings in a table mounted router.....any job that requires guide bushings would be eaiser and safer to do with a hand held router.
walowan is offline
post #6 of 9 (permalink) Old 12-03-2013, 01:41 PM
First Name: Patrick
I agree for some jobs, particularly any time the cutter would be concealed from view, such as patterned recesses in the interior of the work piece. However, for full depth or perimeter pattern work, if the work piece fits comfortably on the table I have no qualms taking it to a table with a bushing.
GCG
___
___
post #7 of 9 (permalink) Old 12-04-2013, 12:37 PM
Bob, I am all for Bosch tools but their router tables fall way short of the mark. Make life easy on yourself and check out the Grizzly T10432. It is low cost and includes all the features you need.
post #8 of 9 (permalink) Old 12-05-2013, 12:15 PM Thread Starter
First Name: Bob
Thanks Mike,
My biggest problem is SPACE.
I have a small single garage to work in, so a bench top table is what I need, and from the research that I have done, the Bosch seems to be the best 'bang for the buck'.
post #9 of 9 (permalink) Old 12-05-2013, 08:07 PM
Bob, it is not difficult to build your own router table. Check out the economy table build sticky thread at the top of this section. This table is designed after the Router Workshop table and should be perfect for your needs.
Triton MOF001 guide bushing problems WoodguyCO Starting Off 6 10-02-2013 11:25 PM
Guide bushing identification Mike Guide Bushings and Templates 42 09-22-2013 09:25 PM
Triton MOH001KC guide bushing plate problem. Warrian Guide Bushings and Templates 6 03-28-2013 11:01 AM
Guide Bushing Height??? english Guide Bushings and Templates 12 02-10-2013 09:35 PM
Guide bushing length crquack Guide Bushings and Templates 17 01-27-2010 07:06 AM
