Bosch 1617- lee valley, or plate in table saw - Router Forums
post #1 of 5 (permalink) Old 12-08-2013, 10:40 PM Thread Starter
knightwsneek2's Avatar
First Name: Ron
Default Bosch 1617- lee valley, or plate in table saw
I have a bosch 1617 and would like help deciding wether to install it in the table saw extension with a bosch insert or to install it in a lee valley steel top router table. Anyone tried either or both of these options ? Also does anyone know where to get insert rings for the bosch platic insert base ? I lve in GTA ontario canada.
Thanks in advance for advice on these options.
knightwsneek2 is offline
post #2 of 5 (permalink) Old 12-08-2013, 10:55 PM
I've had a LV steel top for 15 years. They are good in almost all ways. They stay flat no matter how big a router you hang under them and most routers will mount in a minute or two. The one big drawback is changing bits. You need to have access to the underside of the table somehow. Either in an open stand or prop one side up if you have it in a larger table. It is fairly heavy which makes it a little hard to manhandle. Also on the up side though are all the accessories available like table mounted guide bushings, the LV micro-adjust fence, etc. While you might have to replace a sagged insert plate, you will never in your lifetime need to replace this table top. Someone will probably still be using mine 100 years from now.
post #3 of 5 (permalink) Old 12-09-2013, 09:31 PM
First Name: Brad
Tagged for interest.
I know amazon.ca and blackrock both have inserts. Not much help on the location.
thedude306 is offline
post #4 of 5 (permalink) Old 12-14-2013, 11:01 PM
jamesamd's Avatar
First Name: james
Home made,in tablesaw,Can't be beat/
Not all that glitters is gold,not all that wander are lost.....
jamesamd is offline
post #5 of 5 (permalink) Old 12-15-2013, 12:54 AM
Ron, as much as I like Bosch tools their router tables are sub par. I do not like steel tables because of the potential for rust which can ruin a project. You might want to jump on the 401 and visit us here in Detroit. The selection available from our local Rockler and Woodcraft stores will make the trip worth while.
Mounting a Bosch 1617 in a table tlsrph Table-mounted Routing 7 03-15-2015 12:24 AM
Grizzly T10432 Router Table Plate (@#$%^) IC31 Table-mounted Routing 21 12-23-2014 03:57 AM
Router for Lee Valley Steel Table keithet Table-mounted Routing 14 04-08-2013 03:58 PM
Bosch 1617 with Oak Park table kawisser Table-mounted Routing 25 09-08-2011 07:09 PM
Router Plate Setback from Front of Table tryingtokeepmyfingers Table-mounted Routing 11 04-01-2011 11:29 AM
