Too many holes!! - Router Forums
post #1 of 7 (permalink) Old 12-14-2013, 12:23 PM Thread Starter
First Name: Al
Default Too many holes!!
Hi Forum. I finally picked up the Freud replacement mounting plate for my Freud Bench Top Table I ordered several months ago. It's great looking plate, now made of aluminum, but, unlike the original plate that was plain, the new plate is pre drilled to take a Freud 1700 router. Why it's pre drilled for a specific router I have no idea. I will have to drill four new mounting hole to fit the router I want to use. This is not a problem but I will finish up with five extra holes I don't want. Without having to file and sand the nice brushed aluminum surface of the plate, does anyone have a solution as to how I can fill these holes? I have contacted Freud to see if they can help. Oldrusty
oldrusty is offline
post #2 of 7 (permalink) Old 12-14-2013, 01:05 PM
Semipro's Avatar
First Name: John_*
Al.
Why do you feel the need to fill this holes?
Thank You John
Semipro is online now
post #3 of 7 (permalink) Old 12-14-2013, 02:59 PM Thread Starter
First Name: Al
Hi John. I realize it will still work, but the holes will continually fill up with sawdust, plus they don't look good. Not sure the filled holes will look better!! Al.
oldrusty is offline
post #4 of 7 (permalink) Old 12-17-2013, 05:26 PM Thread Starter
First Name: Al
Problem solved thanks to Freud Canada who have offered to exchange my drilled plate for a blank plate. Great. Oldrusty.
oldrusty is offline
post #5 of 7 (permalink) Old 12-17-2013, 09:45 PM
Semipro's Avatar
First Name: John_*
That is one way to fix the problem
Thank You John
post #6 of 7 (permalink) Old 12-26-2013, 10:10 AM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Al.
I purchased an aluminium plate but it had so many holes to fit several routers models... excluding my Bosch 1619EVS, of course. I didn't want to drill four more holes so I used that one as a template to make an insert plate out of 12mm bakelite plate I had laying around my garage.
Then I used the routerīs sub base as a template to drill the proper holes.
We, woodworkers are everywhere!!!
papasombre is offline
post #7 of 7 (permalink) Old 12-26-2013, 10:20 AM
Al, I think if I was going to fill the holes as you were going to do I would cut the heads off some flat head screws and use some metalized epoxy to glue them in the holes.
Need to drill a lot of 42mm holes mikeoleary Starting Off 11 11-28-2012 01:59 AM
Cutting small holes lilcee Wood Scrolling 3 07-14-2012 07:26 AM
Drilling Holes For Small Hinges Jerry Bowen Tools and Woodworking 24 06-27-2012 04:00 AM
Which holes do I use to attach freud ft2200 to mounting plate? Jmacdona Table-mounted Routing 7 05-22-2012 11:46 PM
which holes? newwoodworker Table-mounted Routing 4 03-31-2009 03:48 PM
