Finger Joint Tearout - Router Forums
post #1 of 9 (permalink) Old 12-17-2013, 10:13 AM Thread Starter
First Name: David
Default Finger Joint Tearout
I experience a lot of frustration attempting to make good finger joints (box joints) on my router table. I have a shop made jig which allows me to cut good sizes and fits, but I can't get away from alot of tearout on the back side of the cut.
Any suggestions?
jdnordstrom2 is offline
post #2 of 9 (permalink) Old 12-17-2013, 10:47 AM
MikeMa's Avatar
Use some sort of backer board behind the work piece. That will go a long way in preventing tear out.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #3 of 9 (permalink) Old 12-17-2013, 01:04 PM
What Mike said and they need to be clamped together snugly to work well.
post #4 of 9 (permalink) Old 12-17-2013, 01:21 PM
Hi David
You can fix that error with a new and very sharp router bit,not all router bits are the same.. some are sharp and some are very sharp...this is one of the times you want to buy the best bit you can find...the good ones are not cheap...
http://www.mlcswoodworking.com/shops...tana_bits9.htm
" High Hook and Shear angles allow cutter to slice smoothly into stock, producing clean splinter free cuts"
Any suggestions?
post #5 of 9 (permalink) Old 12-17-2013, 03:50 PM Thread Starter
First Name: David
Any suggestions for router bit make or style?
post #6 of 9 (permalink) Old 12-17-2013, 05:37 PM
First Name: Al
I don't have a lot of experience but I've had good success with MLCS spiral bits that are not expensive. The use of a backer board works great. You can even add a board in front, even better. Oldrusty.
oldrusty is offline
post #7 of 9 (permalink) Old 12-18-2013, 06:53 AM
kywoodchopper's Avatar
First Name: malcolm
Hi David, I make box joints all the time. The only time I get tear out is with rosewood since it is so brittle. In those cases I have to put a board in front and rear of the work piece. I use Whiteside spiral bits and I am very pleased with the results. I have also noticed that the work piece may be clamped to the fence, but it may not be completely flat. Sometimes I have to use two clamps to ensure the work piece doesn't vibrate. For the backer board I like to have it supporting the work piece on both sides of where the router bit will cut plus pass the spacer pin so that I can clamp the work piece from both sides. To do that I take a scrap board and start cutting box joints until I get about 1/2 way across the board. I then stop the router and move the board from the last cut and over the spacer pin. This board will be my new back support board. I screw it to the original backer board. Since you can not replace the original board without it changing the distance between the spacer pin and the router bit. I hope I explained that well enough. Malcolm / Kentucky USA
kywoodchopper is offline
post #8 of 9 (permalink) Old 12-18-2013, 08:32 AM
I also use the Whiteside spiral up cut bits and am very happy with the results.
post #9 of 9 (permalink) Old 12-18-2013, 08:49 AM
walowan's Avatar
First Name: Michael
I find that tear out is less of a problem using a table saw with a dado blade for box joint projects, but do still use backer boards.
walowan is offline
The difference between a box joint and a finger joint bit Mike Router Bits - Types and Usage 6 09-08-2014 01:21 PM
dovetail and finger joint on hybrid pantorouter samurai Jigs and Fixtures 5 08-06-2012 11:38 PM
Finger Joint Bit Which one? MarlaS Router Bits - Types and Usage 9 11-07-2011 12:48 PM
finger joint bit for edge to edge atmartin23 Router Bits - Types and Usage 20 09-04-2009 01:51 PM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 08:52 AM
