Rewiring Router Switch??? - Router Forums
post #1 of 18 (permalink) Old 12-20-2013, 12:05 PM Thread Starter
First Name: Cliff.
Default Rewiring Router Switch???
I have a Triton MOF001C (2-1/4 hp) router on a Bench Dog ProTop Contractor Table.
I would like to rewire the router so that I can have a more conveniently placed switch on the outside of the router table to turn the router on/off. Has anyone here done this with a Triton router? Is so, how? Pics? Thanks.
Cliff.
boxedin is offline
post #2 of 18 (permalink) Old 12-20-2013, 02:39 PM
I would switch the outlet box you plug it into or use a foot switch before I would rewire the router. You can use a standard light switch to turn the power on and off or you could get a paddle switch from someone like Grizzley to do that with.
Welcome to the forum by the way..
post #3 of 18 (permalink) Old 12-20-2013, 02:50 PM
Semipro's Avatar
First Name: John_*
Hey Cliff, glad to see you join our community.
I agree with Charles number of manufacturers make external switches, kreg rockler,woodcraft and numerous others.
Thank You John
Semipro is online now
post #4 of 18 (permalink) Old 12-20-2013, 04:54 PM
Exclamation No...no...no
Cliff.
Don't do it...The safety sliding switch is there for a reason....
Sydney, Australia
jw2170 is offline
post #5 of 18 (permalink) Old 12-21-2013, 07:44 AM
First Name: Kurt
I have the same router... I put an outlet inside the table base and wired it to a switch on the outside...
Oakwerks is offline
post #6 of 18 (permalink) Old 12-21-2013, 09:34 AM
First Name: Buck
I agree with the above. I've done it on both of my router tables. The additional comment I will make is to use a paddle switch that is located in a location where you can easily hit it with a knee. Don't depend on having to use your hands to shut it down.
BOjr is offline
post #7 of 18 (permalink) Old 12-21-2013, 10:54 AM
david_de's Avatar
First Name: Dave
Cliff.
I misunderstood his post on the first read. From what Cliff said I think by "rewire the router" he did not want to actually do wiring in or on the router itself. It sounds to me as if he is looking for ideas on an external switch as well as location and mounting same on his brand/type router table.
I am sure there must be some members that have the same combination or similar who already have done so. To me pictures are the easiest way to explain something like this. I could post a picture of a paddle switch mounted on an old Delta table saw base under my shop built router table with a HF router but I think it is probably not even close to his situation.
david_de is offline
post #8 of 18 (permalink) Old 12-21-2013, 11:37 AM
http://www.routerforums.com/project-...re-one-up.html
post #9 of 18 (permalink) Old 12-21-2013, 04:28 PM
locin's Avatar
First Name: Nicko
Hi Cliff and welcome to the forum,
I have attached some photos of how I attached my Router which is a 3 hp triton and my shop vac. The power point attached to the table is plugged into any power outlet in the garage/workshop, the router is plugged into the shop vac and the shop vac is plugged into the power point on the side of the table. I leave the router on (except when changing bits), when I flick the power point on the side of the table both the shop vac and the router start.
Hope this helps,
Nicko
Name:	2013-12-22 09.13.17.jpg
Name:	2013-12-22 08.57.36.jpg
Name:	2013-12-22 08.39.18.jpg
locin is offline
post #10 of 18 (permalink) Old 12-21-2013, 05:06 PM
MT Stringer's Avatar
I use a switch from Rockler.
MT Stringer is online now
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Craftsman Router replacement switch BobBratton General Routing 12 12-19-2012 07:49 AM
Milwaukee 5625-20 15 Amp 3-1/2-Horsepower Fixed Base Variable Speed Router Review woodrouterreviewsguy Tool Reviews 1 02-23-2012 10:35 PM
