Power Feed vs. Horizontal Table - Router Forums
post #1 of 5 (permalink) Old 01-02-2014, 06:50 AM Thread Starter
First Name: Wayne
Default Power Feed vs. Horizontal Table
It's interesting that there is talk of the horizontal table. Yesterday I mounted up a very hefty base molding bit from Eagle America and ran through some 8 FT boards on my table. I'm not super impressed with my work, I can use the moulding since I'm going to have to cut parts out anyhow, but it got me thinking that buy using a power feeder or horizontal table, I would have been better off. With a much of crown molding coming up, I want to do that right.
The question is, would a horizontal table or power feeder be a better option?
Thanks!
Wayne
wbrisett is offline
post #2 of 5 (permalink) Old 01-03-2014, 09:19 AM
First Name: Dennis
Hi Wayne
I don't know about a power feeder on a router table but I have one on a 3 horse power shaper that will turn out moldings that are good. The feeder runs stock thru at a constant speed and constant pressure so I would think it would work equally well on a router table if you can mount it securely. I'm sure others on the forum have done this and maybe they will comment.
Dennis
Tough as nails and nearly as smart
Good tools don't cost- they pay!
64 ford is offline
post #3 of 5 (permalink) Old 01-03-2014, 12:04 PM
A power feed would probably make a difference, I know it makes a difference when ripping on a table saw. Problem is that a power feeder is worth from 2 to 4 times what you pay for a router.
When you ran the moulding through did you run it in one pass? I've always seen it recommended that you run large profiles like that in about 4 passes of different depth. If you want to make a lot of moulding you might want to take a look at the Woodmaster planer molder. Wood Molder Planer Machines - WoodMaster Tools
I watched one work at a woodworking show a number of years ago and it did an impressive job.
post #4 of 5 (permalink) Old 01-03-2014, 01:25 PM
First Name: Dick
Wayne if you are only doing one kitchen I would think you could do a fine job by using 4 descent featherboards on a table with no problems at all. Usually there is no problem of burning your wood with a good sharp bit, and chipping is not as much of a problem if the featherboards are set up right. You may need to use 2 double stacked sets on the flat side, but that would still be the least expensive option.
Where there's a Willis there's a way!
Willway is offline
post #5 of 5 (permalink) Old 01-03-2014, 01:49 PM Thread Starter
First Name: Wayne
Thanks folks. I ordered a HP Power Feed unit. It should be plenty big for the router, the bonus is I can move it over to the cabinet saw and use it there as well.
Willway: I used three feather boards, and multiple passes, but the slightest little tilt from me things are a wee bit off (and on 8 FT sections of pine, that's going to happen).
I don't really mind too much on the baseboard project, but for the crown molding, I'm going to do some more ornate things and can't have it off.
Thanks again folks.
wbrisett is offline
Using router for glue up Mickeyt Table-mounted Routing 26 01-18-2016 10:21 AM
Horizontal Router Table Wood-Chuck Table-mounted Routing 25 08-23-2013 06:15 AM
Routing table, routing table Dremel Dremel sander, Dremel Saw horizontal construction oercili Table-mounted Routing 4 04-30-2013 07:42 AM
vertical table equals horizontal router paduke Table-mounted Routing 22 06-16-2011 07:15 PM
Vertical vs Horizontal Table?? TinyElvis Table-mounted Routing 1 04-27-2005 03:29 PM
