Centering - Router Forums
post #1 of 5 (permalink) Old 01-11-2014, 06:42 PM Thread Starter
First Name: Al
Default Centering
Just a short question. Is there really a need to have a router perfectly centered in a router table mounting plate? I understand the reasons for having it centered on a base plate for freehand use. Al
oldrusty is offline
post #2 of 5 (permalink) Old 01-11-2014, 07:03 PM
Al, your router must be centered properly if you want to use guide bushings. If you will not be using them all that matters is that your bits fit through the hole.
post #3 of 5 (permalink) Old 01-11-2014, 07:11 PM Thread Starter
First Name: Al
Hi Mike, that's exactly what I thought. I've suffered the results of off centered bases in template routing freehand. Al
oldrusty is offline
post #4 of 5 (permalink) Old 01-12-2014, 07:14 AM
bowled00's Avatar
First Name: David
Mine's 1-2mm off centre. No ill effects until I used a rebate bit which just brushed the edge of the smallest insert. If centred it would have passed through fine. Otherwise no problems
bowled00 is offline
post #5 of 5 (permalink) Old 01-13-2014, 10:52 PM
jamesamd's Avatar
First Name: james
No.
Not all that glitters is gold,not all that wander are lost.....
jamesamd is offline
Centering your router on a mounting plate Mike Table-mounted Routing 61 01-08-2016 11:28 AM
Bosch Centering Cone JudgeMike General Routing 19 04-30-2012 12:47 PM
Centering cone? fooser Table-mounted Routing 7 09-08-2011 03:46 PM
router centering guide for centering inlay bits frankb General Routing 1 02-25-2011 03:00 AM
Incra Auto Centering Scale Zurt Table-mounted Routing 1 01-24-2011 11:07 AM
