Routering Inside The Edges - Router Forums
post #1 of 3 (permalink) Old 01-13-2014, 04:51 PM Thread Starter
Selwyn Senior's Avatar
First Name: Peter
Default Routering Inside The Edges
I am working on a charging station for my grandsons' multitude of electronic devices. Routering the edges with a round overbit is no problem. The end caps are similar to the shape of a church pew and I'd like to router inside the edges to take away from their planeness. How can I router a groove say an inch inside the edge? Any other suggestions for dressing up the end caps would be greatly appreciated.
Selwyn Senior is offline
post #2 of 3 (permalink) Old 01-13-2014, 10:45 PM
Easy. Make a template to follow. You can use a flush trim or pattern bit to follow the curve of the end cap to make the template if you make the end cap first and then use it to make the grooves. If you make a template to make the end caps, use it to make the grooves too.
post #3 of 3 (permalink) Old 01-14-2014, 11:42 AM
bcfunburst's Avatar
First Name: Reg
You can do a lot more work on inside edges before you do any assembly. I always have great 20/20 hindsight!!
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
Show me your edges noone Router Bits - Types and Usage 1 05-14-2013 08:53 AM
Router bits no longer fitting inside collet? Sheshu General Routing 5 11-20-2012 10:32 AM
Question about finish inside cabinets N'awlins77 Tools and Woodworking 14 04-28-2012 04:32 AM
How to best dress up the edges on Rockler table top? xvimbi Table-mounted Routing 2 08-06-2010 02:39 PM
Poly the inside of furniture? WoodyRon The Finishing Touch 4 09-11-2007 08:28 PM
