Adding Miter Track - Router Forums
post #1 of 5 (permalink) Old 01-19-2014, 05:04 PM Thread Starter
First Name: Bob
Default Adding Miter Track
I have a older CMT Router cabinet modle 999.402.00 it has no miter slot. There is not a lot of room to install one on the front of the cabinet. The top of the cabinet is 1 1/8 thick, I think there is sufficient depth,but am concerened with the width. From the edge of the drop in plate to the outer most edge of the cabinet is 2 inches. The miter will be 3/4 inch wide,leaving me with an 1 1/4 material to work with. Centering the slot within the center of the 1 1/4 inch thats left, gives me 5/8th on each side of the 3/4 miter slot. My question is, is this enough material to cut the miter slot,or should the bottom side be beefed up. The thickness of the top diminishes 3/8th under the slot leaving only 3/4in thickness.
Bob
roundsquare2 is offline
post #2 of 5 (permalink) Old 01-19-2014, 07:16 PM
Forum Moderator
Semipro's Avatar
First Name: John_*
Hello Bob, welcome the router Community.
Is there more room at the back of the table Can you reverse the fence and use the back side of the table
Thank You John
Semipro is offline
post #3 of 5 (permalink) Old 01-19-2014, 10:04 PM Thread Starter
First Name: Bob
Semipro thanks:
I think so however I'm away from the shop now,and my memory,
of the back side of the table is not repeatable until I go and measure it. My profile already denotes tools in shop and years experience
Bob
post #4 of 5 (permalink) Old 01-19-2014, 10:12 PM
Forum Moderator
Semipro's Avatar
First Name: John_*
Bob
My Standard greeting for everyone
Thank You John
Semipro is offline
post #5 of 5 (permalink) Old 01-19-2014, 10:47 PM
Bob check out the thread "Router table top material?" currently running. I would ask why you want a miter track. They aren't absolutely necessary.
distance between miter track and bit DONN48 New Member Introductions 9 03-03-2013 06:27 AM
Bit for cutting slot for Miter Track Racer2007 Table-mounted Routing 4 08-31-2011 11:01 PM
Miter track recommendation ccmnova Table-mounted Routing 11 05-16-2011 10:58 AM
Miter Track and T-track on router table? JAMcDonald Table-mounted Routing 14 04-23-2011 07:11 PM
Distance from miter track to the bit skeet1958 Table-mounted Routing 12 02-21-2011 04:31 PM
