Air flow through routers - Router Forums
post #1 of 7 (permalink) Old 01-20-2014, 01:51 PM Thread Starter
First Name: Mark
Default Air flow through routers
Do all routers flow air through from top to bottom? I can see where good dust collection could really extend the service life of a router if mounted in a table inverted. Do any vent air through the sides instead of the bottom?
Surely none vent from bottom to top. It would seem to be a great way to fill the motor with dust.
Blooch58 is offline
post #2 of 7 (permalink) Old 01-20-2014, 02:46 PM
As far as I know all router fans vent air from top down past the bit. This makes sense in 2 ways. First, it helps keep dust and chips out of the motor. Second is that there is heat produced at the cut so pulling hot air from there doesn't make sense.
I have my dust collection behind the bit on top of the table and I get 95% or better for most operations. Many of the manufactured systems also collect from that spot.
post #3 of 7 (permalink) Old 01-20-2014, 08:41 PM Thread Starter
First Name: Mark
I was watching a review of a popular router and the reviewer was going on how the air flow was going from top to bottom like this was something new. Hence the question.
I have a cheap router with a plastic cooling fan. While rolling some edges some of the fins broke out and fell down by the bit. Wonder if any manufacturer uses a metal fan?
Blooch58 is offline
post #4 of 7 (permalink) Old 01-20-2014, 10:47 PM
I don't know. The plastic ones should be fine if they are the right plastic.If you lost very many fins you should try and replace it.
post #5 of 7 (permalink) Old 01-21-2014, 06:25 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
The Router is designed to work as it does, if it get too much dust internally then try blowing it out, I would as I would not leave the dust in there. N
Last edited by neville9999; 01-21-2014 at 06:26 AM. Reason: same old reason, can't type and can't spell
neville9999 is offline
post #6 of 7 (permalink) Old 01-21-2014, 05:21 PM
JOAT's Avatar
First Name: Theo
I don't know which way the air flows in mine, several older Craftsmans. They are only used in my router table. What I do know is that I have opened a couple up, and there was not a speck of dust in either. And I know that a lot of dust is generated, and goes thru the hole for the bit - and then is blown mostly in my lap (I sit while using them).
JOAT is offline
post #7 of 7 (permalink) Old 01-21-2014, 10:39 PM Thread Starter
First Name: Mark
So it is not a big problem, the air flow through the router motor, that is. Guess it was advertising that caught my eye.
Blooch58 is offline
Router Table Build (pic heavy) 2bigfeet Table-mounted Routing 42 12-04-2011 11:31 AM
Things You Need To Know About Woodworking Routers learnexperience General Routing 11 10-16-2011 05:55 PM
Dylos Air Quality Monitor Group Buy BigJimAK The Bargain Bin 0 07-28-2011 12:46 PM
Table mounting questions for a Craftsman router. tdsapp Table-mounted Routing 25 12-17-2009 08:58 PM
