End of wood routed deeper than rest - Router Forums
post #1 of 14 (permalink) Old 01-24-2014, 12:39 PM Thread Starter
First Name: Pete
Default End of wood routed deeper than rest
Hi all, have a crappy craftsman plastic router table. Has a plastic fence with adjustable guides to open or close the area to each side of the bit, no matter what I try cannot keep the last part/inch of the wood being routed from being cut 'deeper' than the rest. Aside from buying another any help appreciated.
Pete in Coastal NC
ptofimpact is offline
post #2 of 14 (permalink) Old 01-24-2014, 02:24 PM
kp91's Avatar
First Name: Doug
Pete,
You can put a sacrifical fence over your plastic fence, then bury the bit into the fence or make a very small window into the piece.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 14 (permalink) Old 01-24-2014, 04:52 PM
That sounds like "snipe".
Sydney, Australia
jw2170 is offline
post #4 of 14 (permalink) Old 01-24-2014, 09:39 PM
I agree with James. Have you tried putting a straight edge across both fences after it is tightened down? I'm also wondering if you are putting so much side pressure on your work that you are bending the fence in. Being that it is plastic it could flex.
post #5 of 14 (permalink) Old 01-25-2014, 09:05 AM
kywoodchopper's Avatar
First Name: malcolm
Hi Pete, if the table top is not flat the begin and end of the cut will be cut deeper. In my younger days I had a plastic router table and it did just that. Put a straight edge over the router table to see if it is flat. If not you could make your own table and probably cost less than what you paid. I have eight router tables and all are shop-made. Years ago a company contacted me to evaluate their router tables. They asked how many tables I owned and the brand. I explained that I like to custom build what I have a need for and that I had purchased two plastic tables and had trouble with both. I make them the height, size and features that I want. They still wanted me to evaluate 8 or 10 tables that they had and most were acceptable and well made. There was only one plastic one and I gave them my honest opinion of each. Malcolm / Kentucky USA
kywoodchopper is offline
post #6 of 14 (permalink) Old 01-25-2014, 11:38 AM
Garyk's Avatar
First Name: Gary
I had a table like you described. It had the split fence. The problem I encountered was when that last 1" passed over the opening the wood had a tendency to dip slightly and caused the problem you have. As Doug suggested bury the bit so the hole is as small as possible so the work piece can't dip inward and remains flat.
Garyk is offline
post #7 of 14 (permalink) Old 01-25-2014, 12:31 PM
bcfunburst's Avatar
First Name: Reg
Default Plastic Router Table
I think a plastic Router Table might work very well to hold a jigsaw or saber saw mounted permenantly. I had a table by Sears just like the one you have. It sagged in the middle from the weight of the router. I shimmed the router from undernieth to get the table level, but there was still some snipe at the last inch of the cut. I tried to adjust the fence in all ways you can think of, with NO success. I gave away that table to a Lady who mounted her jigsaw in it. Works great for her!!.
I have a used Veritas RT system now and NO more agrivations like the b4 mentioned. I do hope you can get a better RT. There are so many friends here to help.
Have a great weekend.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #8 of 14 (permalink) Old 01-26-2014, 06:49 AM Thread Starter
First Name: Pete
Thanks to all, I shall try some of the kind suggestions, and if is still a crappy table, may have to try a table build. By the way the router that came with it is crappy also. I have a handheld craftsman from over 25 years ago, works better than the 'new junk'
Pete in Coastal NC
post #9 of 14 (permalink) Old 01-26-2014, 08:04 AM
Are you using a bit with a bearing with the fence?
Tom King is offline
post #10 of 14 (permalink) Old 01-26-2014, 08:47 AM Thread Starter
First Name: Pete
Tom, no to that, just the low end craftsman bits, no bearings.
Pete in Coastal NC
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 12:03 PM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 04:01 PM
finishes for routed wood signs bob e The Finishing Touch 20 02-01-2009 04:19 PM
Using India ink for coloring routed signs bob e New Member Introductions 2 12-06-2008 12:54 AM
How to identify wood species: allthunbs Tools and Woodworking 11 12-04-2008 12:28 PM
