Routing Bullnose on Inside of a Circle - Router Forums
post #1 of 16 (permalink) Old 01-26-2014, 03:19 PM Thread Starter
First Name: Dominic
Default Routing Bullnose on Inside of a Circle
I'm trying to make a set of wooden gymnastics rings. The inner diameter is 8". The thickness of the stock is 1 1/4".
I have a 5/8 bearing guided roundover bit; however, I find that my reference edge is removed by the first pass, so that when I flip the piece over to rout the opposite edge, the second pass cuts too deeply. If I lower the bit (so as to keep the reference edge intact), then I don't get a true circle profile, but rather a flat spot along the centerline.
I also have a 1 1/4" bullnose bit that will cut the entire round profile in a single pass. This eliminates the flat spot or vanishing reference edge problems, above. The bullnose bit does not have a bearing to guide it, so I use the router table fence the rout the outside edge. Any suggestions as to how to rout the inside of the circle using the bullnose bit? I was thinking a round fence that matches the inside diameter of the circle with bullnose bit positioned through a hole in the circular fence so that the cutting edge protrudes a hair past the edge of the circular fence. Any suggestions would be most welcome. Thanks!
domjdmba is offline
post #2 of 16 (permalink) Old 01-26-2014, 03:28 PM
Welcome to the forum
I would cut a circle template and use the round-over cutter with a guide bush.
Sydney, Australia
jw2170 is offline
post #3 of 16 (permalink) Old 01-26-2014, 04:06 PM
Gaffboat's Avatar
First Name: Oliver
Originally Posted by jw2170 View Post
welcome to the forum
i would cut a circle template and use the round-over cutter with a guide bush.
+1
Gaffboat is offline
post #4 of 16 (permalink) Old 01-26-2014, 04:12 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router forums Community.
I have use the round over bit for one side and put a little larger bearing on and route the other side not perfect but will sand to round
Thank You John
Semipro is online now
post #5 of 16 (permalink) Old 01-26-2014, 04:38 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #6 of 16 (permalink) Old 01-27-2014, 12:40 AM
Another option is to put a bearing on the shaft of the bullnose bit with a lock collar to hold it in place. Then you can attach a circle template to the ring. It would be nice to find a bearing that is the diameter of the bit in the centre of the concave but you can adjust the size of the template to make up for one that isn't the right size.
post #7 of 16 (permalink) Old 01-27-2014, 05:57 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Mr. n/a, a name would be nice, You did not say what these rings that you will make will be used for. So will they hold the weight of an athlete? If they do then are you sure that you can make these rings out of wood and they won't collapse when some gymnast is swinging giant circles and upside down? If these home made rings break then so does someones back, or have I missed something about the rings you intend to make? If these rings will hold an athletes weight and you do not know how to do that so they will never break then this is one of those times that you buy ones that come with manufacturers warrantee, someone who has insurance concerning rings breaking. NGM
neville9999 is offline
post #8 of 16 (permalink) Old 01-27-2014, 06:16 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Further to Neville's comment, if you are using a single solid piece of wood, you will have 2 weak spots, where the short grain is exposed - to overcome this you should laminate 2 pieces of wood with their grain directions at right angles.
Wildwood is offline
post #9 of 16 (permalink) Old 01-27-2014, 09:11 AM
First Name: Dennis
This looks like a potential liability issue as well as not wanting someone to get badly injured.
If you do this any of the ways described should work. Perhaps,laminated Birch plywood or something similar would be safer.
Dennis
Tough as nails and nearly as smart
Good tools don't cost- they pay!
64 ford is offline
post #10 of 16 (permalink) Old 01-27-2014, 09:53 AM
I've gone back and reread your post DOMDJMBA and it appears you intend to make them from one solid piece of wood. Read Neville's post carefully and then forget about making your own rings.
Use of template Guides cutter79 Guide Bushings and Templates 6 08-21-2013 03:18 AM
Routing a small circle on a small board. swartzwalker Portable Routing 10 03-04-2013 07:51 AM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Routing inside segmented curves ramblingroaddesigns Shop Safety 1 07-08-2009 08:57 PM
Routing a decorative edge on the inside of a faceframe? Woodworker 52 Portable Routing 2 01-29-2008 01:00 PM
