Question about cutting dados - Router Forums
post #1 of 8 (permalink) Old 02-09-2014, 10:40 AM Thread Starter
First Name: Bernie
Default Question about cutting dados
Hi, I'm new to Router Forums and to working with routers. I have a fixed base router installed on a router table. I'm trying to make a cross out of 3/4" square hard wood 6" long using dados to flush fit the cross together. I tried using a 3/4" Straight Bit & it tore the hard wood up. I don't know if I took too big a bite or if I'm using the right bit. I also have a "bottom cleaning dado bit 3/4" x 5/8". Please tell me where I went wrong??? Thanks, Bernie
Soda Pop Cowboy is offline
post #2 of 8 (permalink) Old 02-09-2014, 04:43 PM
First Name: Earl
Welcome aboard Bernie.
I'm guessing you want the dado to be 3/8" deep, so the pieces lap? If so, 2 passes would be in order. Also, using a backer board (push the workpiece through the bit with a sacrificial scrap) on the cut will help as well. Keeps from tearing the fibers out on you good piece.
If your strips are not already cut to 3/4" square, you might want to try cutting the dado in a wide piece, then ripping 3/4" wide sections off that--only one "exit wound" that way.
earl
greenacres2 is offline
post #3 of 8 (permalink) Old 02-09-2014, 09:02 PM Thread Starter
First Name: Bernie
Thanks Earl, I did use a backer board but I'll try taking smaller bits. My hard wood is already cut to 3/4". I thought about cutting the edges out with a band saw, then making passes with the bit. What do you think? Thanks again, Bernie
post #4 of 8 (permalink) Old 02-09-2014, 09:48 PM
Hi Bernie, do you mean half lap joints instead of dado?
http://www.routerforums.com/general-...s-project.html
Sydney, Australia
jw2170 is offline
post #5 of 8 (permalink) Old 02-10-2014, 06:54 AM Thread Starter
First Name: Bernie
Hi James, I am really new to working with routers and don't know the terminology. I'm trying to cut grooves in two pieces of wood to make a cross that fits flush. Bernie
post #6 of 8 (permalink) Old 02-10-2014, 07:10 AM Thread Starter
First Name: Bernie
Something else I have thought about is using double sided tape and running several pieces through at the same time. I'm working with 3/4 inch x 3/4 inch x 6 inch long Granadillo wood. What do you guys think? Thanks, Bernie
post #7 of 8 (permalink) Old 02-10-2014, 05:24 PM
Hi Bernie, did you have a look at the post I had linked in my response?
A simple jig that you could even use with a mitre gauge if you had one....
Sydney, Australia
jw2170 is offline
post #8 of 8 (permalink) Old 02-11-2014, 07:20 AM Thread Starter
First Name: Bernie
James I didn't notice the link. Thanks for bringing it to my attention. I'll check it out.
Profile Cutting Options BobCAD CAM aldepoalo CNC Routing 0 02-08-2012 10:49 AM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
Joining Question nwilliams Tools and Woodworking 3 12-07-2010 05:03 PM
Dados and Bits Question Ariel General Routing 4 01-23-2008 08:16 PM
