Are there routers other thanTritons that have above-the-table features built in? - Router Forums
post #1 of 32 (permalink) Old 02-09-2014, 11:51 AM Thread Starter
Default Are there routers other thanTritons that have above-the-table features built in?
I want above-the-table height and bit changes. Could buy a lift, I know, but it seems easier and cheaper to buy a router with those features built in. I know they are found on the Triton routers...are the present in other brands?
Also, to reduce the cost of building a table, can I skip the plate and bolt the Triton or Triton-like router directly to the underside?
Harvey Dunn is offline
post #2 of 32 (permalink) Old 02-10-2014, 08:05 AM
Yes there are. The Porter Cable 892 has above the table depth adjustment. The speed setting is not adjustable from above the table. I mounted mine directly to the underside of my homemade table. I routed out a circle on the underside so that the thickness was reduced to about half and then mounted the router using longer screws. I plugged it into an outlet strip and that is my on-off switch. I bought the combination router kit that includes a plunge base and I have been happy.
michmags is offline
post #3 of 32 (permalink) Old 02-10-2014, 09:59 AM
Country: Brazil
First Name: Hamilton
Bosch MRC23 also has above the table depth adjustment.
Regards,
hfortes is offline
post #4 of 32 (permalink) Old 02-10-2014, 10:53 AM
MikeMa's Avatar
Bosch 1617 does as well.
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #5 of 32 (permalink) Old 02-10-2014, 01:18 PM
rwl7532's Avatar
First Name: Ralph
I made a long dowel from hardwood with a notch on the end. I use it instead of the Triton crank. Works well.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #6 of 32 (permalink) Old 02-10-2014, 02:18 PM Thread Starter
Thanks. Above the table height adjustment is very nice...but how do you change the bits on those models?
post #7 of 32 (permalink) Old 02-10-2014, 06:06 PM
Adding a Musclechuck to many routers allows the bits to be changed above the table. This requires removable rings to access the factory collets/nuts.
Name:	Milwaukee 5625 Type 8.jpg
Name:	Milwaukee table.JPG
post #8 of 32 (permalink) Old 02-17-2014, 07:18 AM
About the question of changing bits; The top of my table is hinged so that I can lift it, put a prop in place to hold it up and change the bits.
michmags is offline
post #9 of 32 (permalink) Old 02-24-2014, 10:08 AM
Country: Brazil
Mike, on the first photo you've posted,we see a Bosch router between other two. Is it the Bosch MRC23?
If not, do you know if the muscleChuck camless quick change type 4 will fit on it?
Regards,
hfortes is offline
post #10 of 32 (permalink) Old 02-24-2014, 12:02 PM
The routers are the Bosch 1619EVS, MRF23EVS and the 1617EVS; all have Type 4 Musclechucks fitted on them. The MRF23 is the fixed base, MRP23 is the plunge base and the combo kit is called the MRC23... same routers.
New to Table mounted Routers cbeats Table-mounted Routing 10 01-19-2013 07:55 PM
Craftex Sliding Table Saw Attachment CX200S CanuckGal Tool Reviews 6 07-02-2012 10:19 AM
top 10 features of a router table wingate_52 Table-mounted Routing 26 08-06-2009 01:32 PM
Looking for input on home built router table italian biker Table-mounted Routing 10 07-24-2009 09:49 AM
User built table jimcrjfo Table-mounted Routing 12 10-22-2004 12:27 PM
