Raised panel bit in Triton router - Router Forums
post #1 of 2 (permalink) Old 02-11-2014, 09:46 PM Thread Starter
First Name: Don
Default Raised panel bit in Triton router
I know the larger 3 1/2 inch panel bits won't fit down in the Triton router but remember seeing a video where a pattern bit was used to enlarge the hole in the base plate using the insert plate as a guide. Has anyone done this or is there another way around it?
Thanks in advance
Salty Dawg is offline
post #2 of 2 (permalink) Old 02-11-2014, 10:11 PM
Don, you can add an auxiliary top to your table and set your bit above your table top. Using a Musclechuck gains you 5/8" which may be enough for the Triton; I will check this tomorrow and post a photo. (This may require a bit extension) Another option is to use vertical panel raising bits.
Raised Panels: Router vs. Table Saw??? PorterCable690 Jigs and Fixtures 77 03-03-2014 07:34 AM
For Sale: Triton TRC001 3-1/4 HP Router oldhippie1951 Woodworking Classifieds 0 08-15-2011 01:30 PM
Dewalt 625 - Large Raised Panel Bit open_market Router Bits - Types and Usage 7 06-22-2009 02:28 AM
Raised panel bit setup? deck99 Router Bits - Types and Usage 4 10-24-2006 11:20 AM
