cut a rabbit on top edge of cabinet - Router Forums
post #1 of 11 (permalink) Old 02-16-2014, 07:14 PM Thread Starter
Default cut a rabbit on top edge of cabinet
Help!!! I had to cut a small cabinet down and now I need to cut a rabbit in the top edge of cabinet. I am asking for ideas on how to do this safely and accurately.
I am thinking that a fence set very close 3/8" from the bit, then set it over the edge of the cabinet. My concern is keeping the router stable.
I would appreciate any ideas you all my have.
WoodguyCO is offline
post #2 of 11 (permalink) Old 02-16-2014, 07:35 PM
Hi Tom,
There will be commercial offset base plates available for your router, but why not make your own out of 1/4" ply and use a bearing guided rabbet cutter?
Make an offset router base: Shop made router jig for edge moulding - YouTube
Sydney, Australia
jw2170 is offline
post #3 of 11 (permalink) Old 02-16-2014, 08:19 PM
MT Stringer's Avatar
I cut a groove in the end of a cutting board. See if that might give you some ideas on how to stabilize your router.
I can't find the pics! :-(
I clamped a 2x4 to each side of the cutting board. Then I made a jig from 2 pieces of 1/2 inch plywood so the router template bushing would be guided along the path. Then I screwed on a stop on either end. The router had a flat surface to ride on and I wound up with a nice hand grip on both ends of the cutting board.
Sorry I couldn't find the pics.
MT Stringer is online now
post #4 of 11 (permalink) Old 02-16-2014, 08:33 PM Thread Starter
I have never use and offset base before. The edge will be 3/8" wide, would an offset base help in this case?
post #5 of 11 (permalink) Old 02-16-2014, 08:37 PM Thread Starter
This sounds like it might work. I'll see if I can do this.
post #6 of 11 (permalink) Old 02-16-2014, 09:05 PM Thread Starter
This might work if I can get a 2x4 inside the cabinet. I guess I could nail it in place the put the jig on top of the 2x4's.
post #7 of 11 (permalink) Old 02-16-2014, 09:19 PM
Semipro's Avatar
First Name: John_*
Double face tape a 2x4 to the opposite side of rabbet and use a rabbing bit that should give you 2" to support the router.
Semipro is online now
post #8 of 11 (permalink) Old 02-16-2014, 09:28 PM
Put your tape on and clamp it for a few minutes. That 2x4 will be stuck like chuck! :-)
post #9 of 11 (permalink) Old 02-17-2014, 01:43 AM
JOAT's Avatar
First Name: Theo
Well, first thing is to make sure the rabbit is dead, before you start cutting on it. That always helps.
See, your teacher was right, spelling 'does' make a difference.
JOAT is online now
post #10 of 11 (permalink) Old 02-17-2014, 02:52 PM Thread Starter
Your right it does make a difference. I will make sure that rabbit is dead before I cut a rabbet. Never was too good at spelling I & E get me every time.
Using router for glue up Mickeyt Table-mounted Routing 26 01-18-2016 10:21 AM
Greater than japa62 Jigs and Fixtures 12 01-16-2013 12:03 AM
Table top rope edge Macsdado New Member Introductions 2 11-15-2012 04:13 AM
Squaring plywood panels ShaneB Table-mounted Routing 46 10-14-2009 05:28 PM
Fastening Router Table To Cabinet DONALD Table-mounted Routing 7 04-03-2005 11:04 AM
