Best adhesive/method for laminating router table tops? - Router Forums
post #1 of 8 (permalink) Old 02-24-2014, 06:44 AM Thread Starter
Default Best adhesive/method for laminating router table tops?
As the title says. I have two 18mm thick MDF pieces and a sheet of formica laminate, what adhesives/methods have you used with good success?
I'm planning on edging the laminated MDF with hardwood then sanding sealer the hardwood edging. I will be making a hardwood framework on the underneath of the MDF which will then sit inside my router table shell/frame.
fleetinglyshort is offline
post #2 of 8 (permalink) Old 02-24-2014, 07:14 AM Thread Starter
Also, if I'm adding a hardwood framework on the underside of the TOp, is it necessary to laminate both faces? I'm sure the hardwood framework should keep things flat enough for the forseeable future!?
post #3 of 8 (permalink) Old 02-24-2014, 08:44 AM
Regular wood glue works fine for the MDF or adding your hardwood trim. Once these have dried use a contact cement to attach the Formica top and bottom. This adds a tremendous amount of rigidity to the top and is the method described in Shopnotes #1.
post #4 of 8 (permalink) Old 02-24-2014, 08:49 AM
kp91's Avatar
First Name: Doug
I have had good luck with the 'nasty smeling' weldwood cement, so-so luck with the water based. If you are going to be as thick as you describe, laminating the bottom is optional, you can seal it with a finish. Most laminate counters sold aren't laminated on both sides.
Just my opinion
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 8 (permalink) Old 02-24-2014, 10:09 AM
eccentrictinkerer's Avatar
First Name: J.D.
I've had good luck with the 'nasty smelling' Weldwood cement, too.
My success rate improved dramatically when I started rolling on two light coats each for the laminate and the substrate. MDF soaks up adhesives like crazy and two coats guarantee coverage.
Give it a try. I promise, the laminate will stick better and longer.
eccentrictinkerer is offline
post #6 of 8 (permalink) Old 02-25-2014, 07:47 AM
First Name: Richard
Send a message via Skype™ to rwbaker
If you do not like the smell use the 3M spray contact cement. Use on 1 piece for semi-permanent and both pieces for permanent. This works for both the MDF and Laminate. Unlike Mike I always use shellac on all MDF products because down south MDF is anything but waterproof and the humidity will eventually cause swelling. It is cheap insurance, does not interfere with the spray contact cement and if you do not believe it, toss a untreated chunk in water and watch it swell.
Good luck - Baker
rwbaker is offline
post #7 of 8 (permalink) Old 02-25-2014, 11:26 AM
Gene Howe's Avatar
First Name: Gene
Living in AZ, I never gave a thought to the swelling of MDF in humidity. Good suggestion Richard. I'd imagine it can get humid in England.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #8 of 8 (permalink) Old 02-25-2014, 10:42 PM
First Name: Jeff
I might be a bit pedantic but I have laminated both sides of 1 1/2 inch ply to eliminate any possibility of bowing and ensure good sealing. The ply was actually 3/4 glued together. I used white laminate so as I can do calculations, etc. on it with pencil. The pencil rubs off easily with alcohol.
Regards Jeff
c3jrf is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 15 01-26-2015 03:30 AM
help me design (and build) my router table cabinet dicktill Table-mounted Routing 13 05-13-2014 09:23 AM
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 02:51 AM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 07:38 PM
