$13 Grizzly insert plate question - Router Forums
post #1 of 10 (permalink) Old 03-06-2014, 04:06 PM Thread Starter
First Name: Chris
Default $13 Grizzly insert plate question
I just bought a few of these:
PT10432047 INSERT W/GUIDE PIN 9 X 12
What is the radius of the corners?
Or ... what is the best way to make a template for the table modifications to accept this plate?
Chris Curl is offline
post #2 of 10 (permalink) Old 03-06-2014, 04:42 PM
Smart choice to buy a few Chris. The quick and easiest way is to buy the Rousseau 3509T installation kit. Another way is to use an interlocking set of guides like the Trend VariJig; Festool has a similar set. You can also take four pieces of MDF or wood and glue up your own by setting the pieces against your plate like the VariJig is connected.
post #3 of 10 (permalink) Old 03-06-2014, 04:46 PM
Hi Chris,
Check out this video..
How To Install Router Plate In Table - YouTube
Sydney, Australia
jw2170 is offline
post #4 of 10 (permalink) Old 03-06-2014, 10:19 PM Thread Starter
First Name: Chris
OK, I can handle this ... but what size bit will give me the correct radius for the corners? A 1/2" bit?
post #5 of 10 (permalink) Old 03-07-2014, 01:32 AM
Chris, this changes by which method you use. The corner radius is 1/2" but if you are using a guide bushing you may need to use a smaller bit to cut the radius.
post #6 of 10 (permalink) Old 03-07-2014, 07:58 AM Thread Starter
First Name: Chris
Thanks, Mike. I am planning to use a flush trim bit with the bearing on the top. If the radius is 1/2", then that would mean I should use a 1" bit, but the shape of the corner does not look like it would match that of a 1" wide bit.
Can I assume that what you mean is that I should use a 1/2" bit? Or is the radius really 1/2", and should I use a 1" bit?
post #7 of 10 (permalink) Old 03-07-2014, 09:35 AM
If you use the Rousseau kit then a 1/2" straight bit is the answer. If you use a bit with the bearing on the shank end your template will need to be thick enough to limit the depth of cut. A better choice might be Rocklers pattern bit as shown below.
post #8 of 10 (permalink) Old 03-07-2014, 02:03 PM
I used that Rockler bit to install my plate and it was super quick and easy. I've managed to find quite a few other things to use it for as well since then.
william_curran is offline
post #9 of 10 (permalink) Old 03-07-2014, 02:14 PM
It is very handy for many shallow jobs Bill, cutting in hinges with a jig is one example. Welcome to the forums.
post #10 of 10 (permalink) Old 03-07-2014, 02:30 PM Thread Starter
First Name: Chris
thanks mike. i have a pretty shallow trim bit, so i think i'm all set
What Router Lift would be the easiest to replace the Insert plate? JohnnyB60 Table-mounted Routing 15 09-02-2013 05:39 AM
Router Table Insert Plate Advice DJMikeT Table-mounted Routing 3 07-24-2013 10:35 AM
My Custom DIY Insert Plate / Router Table Project BRAVOGOLFTANGO Table-mounted Routing 21 10-17-2012 08:52 PM
Anyone have the smaller Router Insert Plate Rockler use to make. amassey08873 Table-mounted Routing 9 07-12-2012 01:15 AM
Samona Insert Plate bill0199 Table-mounted Routing 9 01-06-2012 02:30 PM
