Is a top speed of 10,000 RPM too slow? - Router Forums
post #1 of 5 (permalink) Old 03-08-2014, 10:07 AM Thread Starter
Default Is a top speed of 10,000 RPM too slow?
I've been looking at the Shopsmith as a possible solution to my extreme space constraints. The new units have additional tilting capability that allows them to be used in a conventional router table configuration (with the bit coming up from under the table, not over the top). Also, the new power plant is impressive - lots of power, lots of torque. However: top speed is 10,000 rpm. Is that too slow for good cuts when using small bits?
Harvey Dunn is offline
post #2 of 5 (permalink) Old 03-08-2014, 10:23 AM
10k is just fine for most router bits,most over spin router bits..
post #3 of 5 (permalink) Old 03-08-2014, 01:27 PM
I took an old router and stripped the armature down and hooked it up with pulleys to a 1hp motor. I estimate that it is turning 10 to 12k rpm and it works fine. Just a little slower feed rate than normal. Pictures are in my uploads. There is very little chance of burning in the cut at that speed.
post #4 of 5 (permalink) Old 03-08-2014, 03:39 PM
Semipro's Avatar
First Name: John_*
Shopsmith makes converters that increase and decrease rpm do not know the cost
Semipro is offline
post #5 of 5 (permalink) Old 03-09-2014, 09:56 AM
Shortslvs's Avatar
First Name: Fred
The new direct drive motors dont require a speed increaser or decreaser for that matter. Lots of guys usingnthe shopsmith for what you want to use it.
They have a forum. Good place to look and ask.
I've owned three and they are fun well built workhorses for the guy without a lot of room. I have lots of room and am thinking about getting another one. Not for all the functions but I once cut one down and used it as a sanding station. I miss it.
Shortslvs is offline
Incra Offset Table Top or Woodpecker Offset Table Top DoItMyselfToo Table-mounted Routing 44 05-08-2013 05:57 PM
What does the back of router table top look like? volunteers Table-mounted Routing 5 07-18-2012 09:54 PM
Minimum RPM for Router Bits joprinz CNC Routing 4 12-19-2010 03:52 PM
Please help - Dewalt Variable speed router - RPM just went beyond the max. paustin General Routing 14 10-30-2010 01:53 PM
"What is it?" #138 reible What is it? 13 10-26-2009 09:07 AM
