Safety Guide Pin - Router Forums
post #1 of 6 (permalink) Old 03-09-2014, 09:08 PM Thread Starter
Selwyn Senior's Avatar
First Name: Peter
Default Safety Guide Pin
My router table while commercially produced lacks a safety pin feature. Any ideas on how
I can install one and where I would locate it? The table has a numberr of interchangable inserts depending on the size of the router bit so do I mount a pin in each of the inserts or on the main body of the table.
Selwyn Senior is offline
post #2 of 6 (permalink) Old 03-09-2014, 10:02 PM
Forum Moderator
Semipro's Avatar
First Name: John_*
Mount on main part table,
Semipro is online now
post #3 of 6 (permalink) Old 03-10-2014, 12:05 AM
Hi Peter, check these videos....
Using a Router Table Starting Pin - Update - YouTube
Safer Routing with a Router Table Start Pin - YouTube
Sydney, Australia
jw2170 is offline
post #4 of 6 (permalink) Old 03-10-2014, 12:17 AM
If you have a plastic plate it will drill and tap just like a metal one will.
post #5 of 6 (permalink) Old 03-10-2014, 06:00 AM
Thanks for info JW2170. I was wanting to do this with my Dremel table. Now all I got to do is find some proper size bits with a bearing. Thanks again.
pretender74 is offline
post #6 of 6 (permalink) Old 03-10-2014, 07:32 AM Thread Starter
First Name: Peter
JW2170 - Thanks for sharing the video links. Both of those were excellent. Much appreciated!
Just discovered I have the safety guide pin oldfolks Table-mounted Routing 0 02-14-2009 08:53 AM
Safety Pin Schmafety Pin RustyW Jigs and Fixtures 6 08-25-2007 11:24 AM
