Which ring to use - Router Forums
post #1 of 3 (permalink) Old 03-16-2014, 06:25 PM Thread Starter
Default Which ring to use
Hello
New here, so here goes! I suppose this has been talked about many times. Over the years I have always wondered about the waste that packs into a dado which is cut on a router table. My question is this, would using a plate ring with a larger opening help reduce the "packing"? I have always believed that the smallest ring that is just larger diameter than the bit is the proper method to help support the workpiece. I have just rebuilt the out feed table on my table saw and incorporated my table router into it, and added a diy below the table dust/chip collector and am wondering if the larger ring opening would help with "sucking" the waste out of dado's etc??
Any ideas?
Ray
1mondo is offline
post #2 of 3 (permalink) Old 03-17-2014, 04:03 AM
Hi Ray.
IMHO, if you are using under the table dust collection, than the normal ring ( yellow?) should suffice for, say, a 1/2" cutter.
There is adequate clearance for the chips to evacuate.
Other may have other opinions.
Sydney, Australia
jw2170 is online now
post #3 of 3 (permalink) Old 03-17-2014, 08:39 AM
First Name: Andrew
Send a message via Skype™ to Roodog
Default router template ring
Hey. If you use a template guide that is just a bit bigger than the bit, of course the waste will fill the gap. If you use a bigger template guide, say a 30mm or 40mm, depending on the cutter you are using, then it stands to reason that the waste will pass through that hole. Problem solved.
Roodog is offline
Collet Extender Nut Larger Than Small Insert Ring Gaia General Routing 7 11-11-2013 06:44 AM
craftsman depth adjust ring will not turn flyinghi3 General Routing 0 02-21-2012 11:05 AM
craftsman router 'ring' bobbb General Routing 2 10-04-2009 01:15 PM
Reducing Ring AnthonyBklyn General Routing 6 05-28-2009 11:45 AM
Ring box inspired by Harry vikingcraftsman Show N' Tell 6 03-16-2009 12:50 PM
