lock miter joint - Router Forums
post #1 of 6 (permalink) Old 03-18-2014, 03:28 PM Thread Starter
First Name: Joel
Default lock miter joint
Hi. I have been trying to set up a freud lock miter bit using a infinity miter jig. I have had nothing but problems, and i think that it is due to the fact that bit is slanted.
Has anybody else had this problem?????
Thanks for the help.
Joel
stripper is offline
post #2 of 6 (permalink) Old 03-18-2014, 04:19 PM
The attached file is from CMT router bits on how to set up the bit.
post #3 of 6 (permalink) Old 03-19-2014, 04:13 AM
First Name: Wayne
Are you using the new Infinity Mitre Lock Jig, or something else?
For those who haven't seen this nifty and inexpensive setup jig: 2-Pc. Lock Miter Master Jig Set - For 3/8 - 1-1/8 Stock-Carbide Router Bits | Router Bit Sets | Shaper Cutters | Saw Blades | Planer Knives | Jointer Knives | Infinity Cutting Tools
I bought one last month, just haven't had the project to use it on yet.
wbrisett is offline
post #4 of 6 (permalink) Old 03-19-2014, 06:30 AM
CharleyL's Avatar
First Name: Charley
The lock miter master 2 pc set is the best way to set up for these cuts. All you need to do is attach the lock miter master to your bit. It just clips onto the bit with the rare earth magnets. Then determine the exact center of your stock, mark it and move the stock over near the lock miter master and raise or lower the bit until the line on the lock miter master lines up with the center thickness mark on your stock. You then move your fence until it lines up with the vertical mark on the lock miter master. One test cut to be certain that the setup is correct and you are ready to cut your joint. It's that easy. The biggest error you will probably make is when you determine the exact center of the thickness of your stock. I do this with calipers, and I now mark from both sides. If my setting isn't right I have 2 marks instead of one and the real center is half way between them. Then it's usually very easy to see and visually mark the center. The lock miter masters work great on 45 deg bits, even different brands of bits, but I haven't yet tried to see if they will work on the 22.5 degree bits. I doubt that they will.
Charley
Central North Carolina
CharleyL is offline
post #5 of 6 (permalink) Old 03-19-2014, 09:44 AM
Gene Howe's Avatar
First Name: Gene
After you've set it up and are ready to run two pieces of scrap, take them to the saw of your choice and cut a 45 on both pieces, leaving a flat on the ends to ride against the fence or table.
You'll find that the cut will be easier without all that wood to hog off.
If everything tests out good, then 45 the work pieces, too.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #6 of 6 (permalink) Old 03-20-2014, 07:44 AM
First Name: Al
I believe Sommerfeld tools has an easy set jig for Freud bits as well in their catalog.
mstrfnsh is offline
A Tall Lock Miter Joint Fence for Ken & Sid Stefang Table-mounted Routing 30 06-21-2015 02:50 PM
Reversible Glue Joint Bit and Lock Miter bit Shells Router Bits - Types and Usage 35 03-10-2014 08:11 PM
Which is the best Lock Miter Bit? RJM60 Router Bits - Types and Usage 13 08-11-2012 06:26 AM
30 degree miter lock bit available? Jlaw Router Bits - Types and Usage 17 04-12-2012 09:16 PM
Lock Miter Bits Ken Bee Table-mounted Routing 2 07-18-2011 06:44 AM
