"Good side down" - Router Forums
post #1 of 11 (permalink) Old 03-20-2014, 08:47 PM Thread Starter
First Name: Don
Default "Good side down"
Ok, fixing to build a bookcase & have been looking at some videos on making raised panel doors & they talk about putting the good side down when using the router table. I have been to a friends shop & helped him with doors & he never made a comment about it. I have got my wood which will be poplar for the doors but when I look at the wood, both sides look good to me. Is there something I am missing here? Thanks in advance for the help.
Making sawdust & scraps all at the same time
Salty Dawg is offline
post #2 of 11 (permalink) Old 03-20-2014, 08:56 PM
First Name: Earl
You're not missing a thing. On some of my wood both sides look great and i wish i could see both in the finished project. Some pieces don't look good on either side--i try to hide those.
In my mind, the reason for "putting the good side down on the table is that the table is the reference point. I try to reference the good side on pieces that meet so that if i'm off, it's most likely on the side that will not show. I want the visible side to meet as closely as possible so the finish work is easier.
Hope that makes sense.
earl
greenacres2 is offline
post #3 of 11 (permalink) Old 03-20-2014, 09:00 PM
BCK
First Name: BC
as said above, good side down just means the best side or side you will have as finished piece that you will be seeing or looking at when assembled and finished...and if using a vertical panel bit it would be good side to the fence..
http://www.natures-lifestyles-digest.com/smf
above [link]site has: outdoors type things from fishing, hunting, boating, hiking, to living off grid, gardening from veggies to flowers etc, recipes from home cooking to smokers, hobbies, home remedies, to making your own soaps etc..live members chat area.. and more...all is welcome to browse or join..
BCK is offline
post #4 of 11 (permalink) Old 03-20-2014, 09:29 PM
JOAT's Avatar
First Name: Theo
For what it's worth, I use plywood in the majority of my projects. There is normally one side clearly better than the other. The good side 'always' goes down - mostly because I tack my masters/patterns/templates down with small nails, which leaves nail holes, which I do not want to show, so I tack them down to the 'bad' side.
JOAT is online now
post #5 of 11 (permalink) Old 03-20-2014, 10:18 PM
Forum Moderator
MT Stringer's Avatar
If you are making the raised panels with one of those big bits, be sure to cut across the ends first, then the long sides. That way any tearout will be cut away.
I have to make three or four passes to get to the final cut.
Good luck.
Name:	2013-10-15 19.52.25.jpg
Name:	2013-10-15 19.51.52.jpg
Name:	2013-10-15 21.44.19.jpg
Name:	2013-10-18 15.24.12.jpg
MT Stringer is offline
post #6 of 11 (permalink) Old 03-21-2014, 04:39 AM
First Name: Wayne
You may also want to watch this video (there are other parts too). When I was trying to figure out how to do my raised panel doors for the first time, this video (I bought it on DVD) helped me out tremendously.
https://www.youtube.com/watch?v=gJcsTt1mn0g
wbrisett is offline
post #7 of 11 (permalink) Old 03-21-2014, 12:36 PM
First Name: Bob
Send a message via AIM to bob156235
Default Good Side Down?
It is only mentioned because the side facing down will be the face you see. The bit profile is cutting back-side up.
bob156235 is offline
post #8 of 11 (permalink) Old 03-21-2014, 06:26 PM
I'm new but when they say good side down, they mean the face of your door frame will always be facing down. When working on a router table so everything lines up.
Mike1961 is offline
post #9 of 11 (permalink) Old 03-21-2014, 07:29 PM
Ah...BJ always talks about the 'magic' 4"......The penny drops.......
I will have to check my R&S cutters and work out the magic number to cut the rails.
Sydney, Australia
jw2170 is offline
post #10 of 11 (permalink) Old 03-22-2014, 02:55 PM
Not mentioned so far is always doing the job the same way to avoid confusion. If you do it the same way each time you will avoid errors.
Table saw-standing on the left or right side. Sawdust Don Shop Safety 45 11-19-2012 08:29 PM
Colt/DeWalt side by side bobj3 Portable Routing 13 03-17-2011 04:45 PM
*New* Side Menu - Need Your Opinion Mark Site Help and Suggestions 9 12-28-2008 09:34 PM
new router has side to side movement whilst plunging??? matey General Routing 2 11-11-2005 02:09 PM
