My vacuum system sucks - Router Forums
post #1 of 13 (permalink) Old 03-22-2014, 07:10 PM Thread Starter
First Name: Don
Default My vacuum system sucks
I have been playing with scraps for the last couple of weeks learning the different router bits I have. I started off today with making the face frame for a bookcase I am building. I got all the pieces cut, pocket holes drilled, the got the table set up to use the tounge & groove bits. I first cut the groove on the side pieces that were 2 1/2" wide, no problems, vac system worked great, then went to cut the 5" wide pieces starting in a little to miss the pocket holes, well thats when I found out how well my vac system works,it sucked the wood into the fence when I got about 1/2" away, it happened so fast & this is the first time I have used a piece this wide, the wood hit the blade & kicked back, bad thing was I was holding the end of the wood with my finger tips & got hit by the blade, thankfully it was just a nick, learned what not to do next time.
Making sawdust & scraps all at the same time
Salty Dawg is offline
post #2 of 13 (permalink) Old 03-22-2014, 07:23 PM
Hi Don.
My guess is that the gap between to infeed fence and the cutting edge was too much and the cutter grabbed the workpiece and dragged it in, not the vac.
Can you move the infeed side of the fence closer in and make a zero clearance ?
This is what happens when you use a bearing guided cutter on the table without a safety/starter pin.
It happens so quick that you thought it was still 1/2" away.
Glad to hear there were no serious injuries......
Sydney, Australia
jw2170 is offline
post #3 of 13 (permalink) Old 03-22-2014, 07:41 PM Thread Starter
First Name: Don
Hey James, went back, turned the vac on with out the router running & it sucked the board in, the infeed side was barely touching the bit, was running the board vertical.
post #4 of 13 (permalink) Old 03-22-2014, 08:01 PM
BCK
First Name: BC
glad no serious injury...
http://www.natures-lifestyles-digest.com/smf
above [link]site has: outdoors type things from fishing, hunting, boating, hiking, to living off grid, gardening from veggies to flowers etc, recipes from home cooking to smokers, hobbies, home remedies, to making your own soaps etc..live members chat area.. and more...all is welcome to browse or join..
BCK is offline
post #5 of 13 (permalink) Old 03-22-2014, 08:06 PM
Wink
OK Don.
Thanks for clearing that up.....
Sydney, Australia
jw2170 is offline
post #6 of 13 (permalink) Old 03-23-2014, 05:24 PM Thread Starter
First Name: Don
OK James, took your advice & made a zero clearance adapter for my fence & it worked perfectly but I get a high pitch noise from the vac port going thru the small opening which is better than the alternative.
post #7 of 13 (permalink) Old 03-23-2014, 06:02 PM
Do you use a 4" vac system on the router table?
I only use my 4" chip collection system on the jointer and thickness planer.
For the router table I use a home vac and Triton dust bucket to collect the dust.
However, I do work out in an open car port.
Sydney, Australia
jw2170 is offline
post #8 of 13 (permalink) Old 03-23-2014, 06:53 PM Thread Starter
First Name: Don
Just a shop vac.
post #9 of 13 (permalink) Old 03-23-2014, 07:00 PM
Don if you are going to start a board anywhere except at the end then you should probably be using a stop block on the infeed side. That will help prevent the router from throwing the piece when it makes sudden contact.
post #10 of 13 (permalink) Old 03-23-2014, 07:30 PM Thread Starter
First Name: Don
Charles, the piece I was using was 32" long for a base cabinet face frame, no problems with the 2 1/2" pieces run vertical as they did not cover the vac port like the 5" pieces did, did not have a problem with the other 3 pieces when I left the shop vac off.
A Point To Remember When Using the Incra LS TS System Jerry Bowen Tools and Woodworking 1 07-10-2013 08:13 PM
Vacuum System Almost Finished MEBCWD Show N' Tell 5 02-09-2012 09:17 AM
Outlook Express problems BrianS Lobby 6 01-06-2008 07:23 AM
Vacuum system on/off ..... reible General Routing 5 10-06-2004 11:06 AM
