Cove Router Bit - Router Forums
post #1 of 8 (permalink) Old 03-23-2014, 10:07 PM Thread Starter
Selwyn Senior's Avatar
First Name: Peter
Default Cove Router Bit
I'm currently building a couple of karate belt display stands for my grandsons. Each unit looks like a floor model trophy. Their earned belts wind around a series of dowels.
To glue the dowels first into the base I want to build a jig that will hold them plumb while the glue dries. Would a cove bit give me a slot in the upright part of the jig that the dowel would fit in? The dowels are 1" and 3/4" diameter.
The jig would be a right angle triangle with extra support at the base. The dowel would rest in the routered slot until the glue dries.
Hope the description makes sense.
Selwyn Senior is offline
post #2 of 8 (permalink) Old 03-23-2014, 10:36 PM
I'm having trouble trying to visualize what you are trying to do Peter. Dowels should be inserted into a drilled hole in which case you don't need a jig to hold the dowel plumb.
post #3 of 8 (permalink) Old 03-24-2014, 12:29 AM
Hi peter, what size dowels are you using and how are you drilling the holes?
I am with Charles on this one....
Sydney, Australia
jw2170 is offline
post #4 of 8 (permalink) Old 03-24-2014, 03:51 AM
I read this again a couple of times Peter and I think I see what you are trying. The floor standing trophy finally clicked. You will be using at least a 3/4" thick base so if you drill the holes with a good brad point bit or a Forstner on your drill press the holes should be tight enough to keep the dowels straight while the glue dries. Since the bottom won't show I would drill all the way through. You didn't say how thick the upper board will be but I would drill it as deep as possible.
Your biggest issue will be lining all the holes up between the two pieces so I would drill the holes in the correct positions through a scrap piece first and then use it as a guide to drill the other holes by clamping it to the pieces you will be using for the stand. That way all the holes will be in the same positions. I would glue it all at one time and then check to see if it is square. If it's not perfect a little twist or push should straighten it out and it should dry straight.
post #5 of 8 (permalink) Old 03-24-2014, 08:54 AM
First Name: Richard
Agree with Charles and James.
Shop guy is offline
post #6 of 8 (permalink) Old 03-24-2014, 08:55 AM Thread Starter
First Name: Peter
Charles & James, thanks for your responses.
The base and top are 3/4" stock.
The holes were drilled using a 3/4" and 1" forstner bits on my drill press.
The dowel fit is tight; however they are about 20 inches long.
Given that much length I was trying to help support them just while the glue dries.
post #7 of 8 (permalink) Old 03-24-2014, 09:13 AM
First Name: Dennis
I would square up 4 pieces of scrap wood and attaché them to the side of the dowel with double sided tape resting them on the base to hold the dowel straight. I would also use wax paper between the scrap support pieces and the base to insure they don't get glued down
Dennis
routergieck is offline
post #8 of 8 (permalink) Old 03-24-2014, 12:30 PM
Peter if you have a corner you can shove it into that will work. A corner of a cupboard, a corner in your house or shop, anything along those lines. Push something against it once it's in the corner to hold it there. There's no reason to make it more complicated than it needs to be.
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 10:46 AM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 05:43 AM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 07:50 PM
