Problem With Raising Triton Router To Lock Spindle - Page 2 - Router Forums
 3Likes
post #11 of 18 (permalink) Old 03-31-2014, 09:27 AM Thread Starter
Talking Triton Router Won't Raise All The Way Up.
Thanks for all the great input guys. I looked at everything that was suggested and everything was as it should have been. I even removed it from the table and tried to plunge it down all the way by hand and that didn't work. The only thing i didn't try was to reset the collate, and as i reflect back on it, the locking pin would line up with the hole ok but it just wouldn't go in so that may have been the issue, but i will keep that in mind for next time if this happens to me again. However, as i said i would keep you updated on any solution i came up with. Well my solution was to put the spring back in, gather up all the stuff that came with it, put it in a box and took it back to Home Depot for a refund. Since they don't carry that unit in the stores i went back online again to Home Depot and ordered another one since they have a 90 day return policy. The reason i got the same one is because most of the reviews i have read were positive and after having used it even just a few times, i really liked it. There are only a few out there that have the ability to raise it from above the table top without an add on raiser. But at least i have a little more knowledge about it now thanks to all of you and your input.
lredhage is offline
post #12 of 18 (permalink) Old 05-10-2014, 08:49 PM
DSF
First Name: David
Default Raising the Triton TRA001 all the way up
Hi, I'm also a new member, so I hope I'm replying correctly. I also have a Triton TRA001 and have had the same problem. I had some luck with it by: keeping the router plugged in, lowering the bit, turning the router on so it spun for a short period, and then raising it up again (with the power off of course). I'm not sure how much of that was voodoo, but it did seem to work.
DSF
DSF is offline
post #13 of 18 (permalink) Old 05-12-2014, 08:56 AM Thread Starter
Ok here is how I finally resolved my problem after trying everything and ending in frustration, I took it back to Home Depot and got a refund. Now maybe i am a glutton for punishment, but I really liked the Triton router so i was wondering around Menards and they happen to carry the Triton so i picked one up and brought it home. I got it all mounted to my table and hooked everything up and turned it on........ nothing happened. I thought i might not have the power on so i putzed around with it a little more, to no avail so i removed it from the table and plugged it directly in to the wall. Still nothing so i packaged it up and took it back. Strike 2. ... When i took it back to Menards they had only one left that was a display model so i had them plug it in to make sure everything worked and it did so i got it home and mounted it to my table and everything is working as it should. Hopefully this is the end of the story because i really do like the Triton.
lredhage is offline
post #14 of 18 (permalink) Old 05-06-2017, 03:09 AM
I know this thread is 3 years old but I believe I know the cause of your original problem. I recently sold my router table with a Triton 3hp router and I was having problems before I sold it raising the router up high enough for the spindle lock to engage. I felt a lot of resistance when raising it. I checked that the power switch was off and the plastic cover over the power switch closed and it was. No visible saw dust or wood was blocking anything.
So I took the router off the table and noticed a black plastic cover on one of the metal posts that allow the router to plunge up and down. So I took that plastic cover off (I believe it is held down by a screw) and noticed it was absolutely packed with saw dust and would not allow the router to raise all the way. I cleared the sawdust out and everything worked perfectly. It allowed me to sell it and not feel guilty as well.
I hope this information helps others who have had this issue.
Herb Stoops likes this.
edwarmr87 is offline
post #15 of 18 (permalink) Old 03-17-2019, 04:51 PM
Andy Bardowell's Avatar
First Name: Andy
SOLVED, found the culprit. Check the spring cover I'll bet that it is packed with saw dust, mine had about a table spoon of compacted material preventing the spindle lock from engaging. Hope this helps in your case as well.
Triton part numbers...
8 TRA 070 Screw, Rack Post Cap
9 TRA 342 Cap, Rack Post
Andy
DesertRatTom likes this.
Andy
Andy Bardowell is offline
post #16 of 18 (permalink) Old 03-17-2019, 10:40 PM
As a happy Triton owner, I really appreciate that someone revived this string. I'll know what to check. Seems to me that Stick suggested running a DC hose up to the bottom of the router so sawdust gets blown out the top and won't get into the works. I find sawdust is sometimes the cupret with I think the height is drifting. It may just be a layer of sawdust built up under the workpiece.
post #17 of 18 (permalink) Old 04-27-2019, 01:23 PM
I ran into this same problem and found another solution that might help someone else in the future. I had been routing pine boards that were still a little wet and I had noticed some dust sticking to the router table but didn't think much of it. Later when I tried to swap bits I couldn't get the lock to engage when I raised the collet. I couldn't even push the collet lock in by hand at first, but once I did I couldn't get it to release again which would be a disaster since the the switch lock would let me turn it on. The wet sawdust had hardenen around the collet locking pin and the hole it moves through. I removed the screw next to the locking pin, removed the spring and plunger assembly, then cleaned out the hole. It works fine now.
JT738 is offline
post #18 of 18 (permalink) Old 04-30-2019, 01:44 PM
Country: Spain
First Name: Antolin Agar Soto
I have had the same problem with a CMT (Triton twin), it happens when you press and turn the right knob then the lever that sets the depth activates. Press the center button of the right knob and release the lever that fixes the depth and solved.
By the way, to work once you have selected the depth you have to activate the depth lever so that the machine does not vibrate.
Nilotna is offline
Drawer lock router bits - size? tdale Router Bits - Types and Usage 24 03-09-2012 05:29 PM
Hitachi M12V2 plunge lock problem to avoid AlanWS General Routing 1 03-25-2011 08:57 PM
Hello DPugmire New Member Introductions 5 11-08-2010 07:29 AM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 05:43 AM
Triton Router & Router Raizer kenrg Table-mounted Routing 18 11-24-2009 01:53 PM
