Build: Drawer slide router lift - Router Forums
post #1 of 26 (permalink) Old 03-29-2014, 04:35 PM Thread Starter
First Name: Chris
Default Build: Drawer slide router lift
I think this a little different setup from most people.
My goal is a router table that has a lift built into the base of the table, i.e. - not hanging from the top like most lifts. Then the top is on a piano hinge that allows me to open it up to make it really easy to change the bit.
This is where I am right now. I have a piece of 3/4-16 all thread on order for the drive, but I think a 3/8-16 would probably be just as good. Next is to build the structure in to the base of he table to attach it.
It shows the router held in place with a zip tie, but that is just for the proof of concept. The real hold down will either be a pipe clamp, or a couple of 1/4-20 bolts with another similar bracket on the other side.
Last edited by Chris Curl; 03-29-2014 at 04:48 PM. Reason: oops - forgot to add the pics
Chris Curl is offline
post #2 of 26 (permalink) Old 03-29-2014, 06:00 PM
Nickp's Avatar
First Name: Nick
Great idea, Chris...I gather then that you found beefy drawer slides with no play...? I've looked in the typical places for drawer slides with no play for other projects but no luck...when you get the time, could you post brand/model and where you got them...?
Thanks so much...good luck with the lift and will be following this closely...I'm still learning...
Nick
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is online now
post #3 of 26 (permalink) Old 03-29-2014, 06:30 PM
First Name: Dick
Does the wire tie hold your router solid without any play?
You might want to make a U-bolt (or two) and utilize it for your own security.
dick in ia is offline
post #4 of 26 (permalink) Old 03-29-2014, 07:36 PM Thread Starter
First Name: Chris
Nick, they are just drawer runners from home depot. I do not detect any play, but if there was any play, I could simply pinch them a tiny bit in the vice which would remove the play.
Dick, it shows the router held in place with a zip tie, but that is just for the proof of concept. The real hold down will either be a big hose clamp, or a couple of 1/4-20 bolts with another similar bracket on the other side.
post #5 of 26 (permalink) Old 03-29-2014, 07:53 PM
Nickp's Avatar
First Name: Nick
Gotcha...thanks...anxious to see your progress and the finished product...Nick
Nick
Points to Ponder...
Nickp is online now
post #6 of 26 (permalink) Old 03-29-2014, 08:46 PM
I would go with a few hose clamps Chris. I would be worried about over tightening with the 1/4 x 20 bolts and damaging the casing on inner components. The base forms almost a full circle around the motor housing but squeezing from 2 sides will tend to want to make it elliptical. I would also look at gluing some high friction material against the wooden block.
post #7 of 26 (permalink) Old 03-29-2014, 10:10 PM
MAFoElffen's Avatar
I like the design of that. See it is coming together now.
MAFoElffen is offline
post #8 of 26 (permalink) Old 03-30-2014, 02:24 AM Thread Starter
First Name: Chris
OK ... new plan ...
When I started trying to work out how to attach this thing to the frame and add in the threaded rod, I was not happy with any of the ideas I had.
Now the plan is to merge the ideas from that lift in the ShopNotes with this lift that Al B Thayer made:
Router Table Lift - Woodworking Talk - Woodworkers Forum
post #9 of 26 (permalink) Old 03-30-2014, 01:16 PM
david_de's Avatar
First Name: Dave
Thanks for posting your R&D on this. Looking forward to the completed project. Some information on why you changed your views on type of lift might be helpful to others as well.
Having the slides adjustable to remove any play is important in my opinion. I have seen the hose clamp mounting the routers and it seemed to work fine. If the saddle is properly made the router would probably set back into the same position if you had to remove and re-install it.
Being able to open (raise) the router table top is a nice idea for cleaning as well as changing the bit. I like raising the chuck above the table to change bits so I do not have to clear everything off the table top to change a bit.
Excessive movement between table and router bit in that configuration (hinged top) might be a problem? Maybe some sort of guides to make sure it locks into the table to reduce any play with the top and the router not attached to each other.
david_de is offline
post #10 of 26 (permalink) Old 03-30-2014, 04:41 PM
MAFoElffen's Avatar
OK ... new plan ...
My favorite design:
https://www.youtube.com/watch?v=pNXWQHx4-7U
Metric Router Lift Availability plunger Table-mounted Routing 19 03-08-2014 10:17 PM
PRL-V2 Router Lift DarkFlame Starting Off 8 03-20-2011 09:01 PM
Hello DPugmire New Member Introductions 5 11-08-2010 07:29 AM
No Lift Systems To Fit Bosch 1619EVS 3.25HP Router? DennisP General Routing 4 01-20-2010 06:23 PM
