flush trimming - Router Forums
post #1 of 22 (permalink) Old 04-03-2014, 01:36 AM Thread Starter
Country: Mexico
Default flush trimming
once you have your template, how do you folks attach it to the Wood you want to shape by flush trimming it.
thank you
fernandito is offline
post #2 of 22 (permalink) Old 04-03-2014, 02:55 AM
Semipro's Avatar
First Name: John_*
If you are not worried about holes nails or screws otherwise double face tape, remember it's pressure sensitive so you need to press it together for a second to make it hold.
Semipro is offline
post #3 of 22 (permalink) Old 04-03-2014, 06:25 AM
Pin nail or double sided 'carpet' tape....
Depends on the size.....
Sydney, Australia
jw2170 is offline
post #4 of 22 (permalink) Old 04-03-2014, 07:03 AM
JOAT's Avatar
First Name: Theo
Can't stand the cleanup with double-stick tape, or rubber cement. Now I drill pilot holes in my templates, and use thin nails to tack them down.
Gather the villagers, pitchforks, torches; we march at dusk!
JOAT is offline
post #5 of 22 (permalink) Old 04-03-2014, 07:24 AM
Selwyn Senior's Avatar
First Name: Peter
I use wide double sided carpet tape which does leave a bit of residue when I take it off but because the time is short I find the glue residue balls up and slides off with minimal effort.
Selwyn Senior is offline
post #6 of 22 (permalink) Old 04-03-2014, 07:54 AM
First Name: Jake
40mm 'Tenacious Tape' brand carpet tape. Don't be shy with it, it comes off the timber easier than the template (I use 6mm clear acrylic).
Jakexp is offline
post #7 of 22 (permalink) Old 04-03-2014, 08:22 AM
Honored Member
First Name: pat
Never with a temporary adhesive (psa) or tape.
Always with clamps (toggles or C), crowders, vacuum, fences and stops.
Quillman is offline
post #8 of 22 (permalink) Old 04-03-2014, 08:45 AM
First Name: russ
Double sided tape for wood turning. Strong, and I have had no problem with residue after. It`s made for this purpose.
russfranken is offline
post #9 of 22 (permalink) Old 04-03-2014, 08:54 AM
thank you
if it's an often used template ... take the effort to set it up to be vacuum clamped in place...
post #10 of 22 (permalink) Old 04-03-2014, 09:01 AM
Bodger96's Avatar
First Name: Bob
I use commercial hot melt glue. To remove spray with methyl hydrate (wood alcohol) and the glue automatically releases. The key is commercial hot melt, not the hooby kind. The first time that I was introduced to this method I scoffed at it being possible. Works fantastic!
Regards Bob
Bodger96 is offline
unique problem flush trimming jwoody New Member Introductions 3 01-01-2013 06:16 PM
My flush trimming split my workpiece ScoFF General Routing 10 08-12-2011 05:16 PM
flush trimming deeprabbet Table-mounted Routing 2 01-31-2011 09:19 PM
flush trimming 3/4" and 1" mdf z399y General Routing 8 05-09-2010 02:09 PM
Good bit for flush trimming thick stock? jimgo Router Bits - Types and Usage 12 03-24-2010 11:30 AM
