Router Table Build Help - Router Forums
post #1 of 6 (permalink) Old 05-01-2014, 06:49 AM Thread Starter
First Name: Scott
Default Router Table Build Help
I just scored a 36" x 30" storage cabinet off craigslist for $25. My plan is to turn it into a nice router cabinet. I have a 2hp craftsman router with a fixed base. I stuck on how I should mount the router to the table. As of right now I was thinking of just screwing it to the bottom of the top and then building different insert plates to sit on top so I can change them with different size cutters.
Anyone have any suggestions?
ssevey17 is offline
post #2 of 6 (permalink) Old 05-02-2014, 01:58 PM
Default Don't do it!
If you screw the router base to the underside of the top, you might have a problem running out of height adjustment on the router (assuming a 3/4 in thick top).
Would really be better to invest in a plate for the router even though it is more expensive and involves a little more work to install.
Breed is offline
post #3 of 6 (permalink) Old 05-02-2014, 05:12 PM
Selwyn Senior's Avatar
First Name: Peter
While the router is fixed there is still stress on the mount as it cuts. You might want to look at a router table insert. I realize it would cost more than the deal you got on the cabinet, but you may find it will give you a better finished product and the ability to better adjust the height of your cuts. Several router table insert plates come with excellent installation instructions.
Peter
Selwyn Senior is offline
post #4 of 6 (permalink) Old 05-02-2014, 08:41 PM
williamm's Avatar
I have seen routers mounted with 3 toggle clamps, screws going down from the top into the base, and even held in place by a hydraulic jack. (I wouldn't recommend the last one) So whatever you can think of that will be safe and meet your needs for depth of cut and ease of access. You will have to change bits once in a while so screwing it to the top will be cumbersome at best. You could make yourself an insert if you want to go for the least expense. There are many ways to solve you problem, it just depends on what you want.
williamm is offline
post #5 of 6 (permalink) Old 05-03-2014, 06:50 AM Thread Starter
First Name: Scott
Thanks for the advice. I did decide to buy a grizzly router plate. I do have a question regarding router plates. I feel like the weight of the router is not enough to keep it from moving a little bit. I'm thinking about epoxying in some nuts on each corner of where the router plate mounts. That way it would hold it in place and I could micro adjust the height of the plate. Thoughts? Have I lost my mind?
ssevey17 is offline
post #6 of 6 (permalink) Old 05-03-2014, 09:17 AM
First Name: Peter
If you do a search "install a router plate" you will find some excellent you tube videos. Several talk about installing screws to level the insert. If installed as outlined there shouldn't be any stress factors.
New Router Table flemingj1122 Table-mounted Routing 13 05-19-2012 03:02 PM
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
New router, need table, building dovetail cabinets santana157 General Routing 7 02-02-2009 11:34 PM
