Dust collection question - Router Forums
post #1 of 7 (permalink) Old 05-06-2014, 07:35 AM Thread Starter
First Name: Steve
Default Dust collection question
My question concerns dust collection on a router table. My table is a "custom" made open stand with a LS system with a wonder fence. The fence does a fair job of removing chips but the downside to that is when the fence is moved away from the bit there is virtually no collection, as I'm sure you all are aware. Incras web site has plans for a down draft box that encases the router that I may build. The problem is don't alot of the chips end up going inside the router? Is there a way to prevent that from happening?
GunnerB52 is offline
post #2 of 7 (permalink) Old 05-06-2014, 12:13 PM
First Name: Phil
Steve, there is a recent thread devoted to this issue and the Keen Dust Router collector as a possible solution. I have benefited from the comments of other participants in this thread and, in fact, have ordered the product. There are videos on youtube and the Keen site which describe the collector and some different installations of it. Since I don't yet have the product to test it, I can only refer you to the above and the link below.
http://www.routerforums.com/table-mo...able-dust.html
Phil
Phil Dalton is offline
post #3 of 7 (permalink) Old 05-06-2014, 12:29 PM
First Name: Gareth
Steve - very valid concern with the router and the collection issue with any router table with dust collection installed in the fence. I would second the Keen Dust Router collector. From the videos it looks nifty. Some on the forum have said that it it binds in the lift and others have said that it does not. The video looks like it works but probably the only way to know is to get it.
DoItMyselfToo is offline
post #4 of 7 (permalink) Old 05-07-2014, 07:10 AM
kywoodchopper's Avatar
First Name: malcolm
Hi Ken, I have two of the Keen Dust Router products. One is mounted on the same setup as yours. It appears to get close to 100% of the dust. Malcolm / Kentucky USA
kywoodchopper is offline
post #5 of 7 (permalink) Old 05-07-2014, 02:40 PM
First Name: Dick
Oh well, another great solution a little to late!
Seeing as how we are making MDF raised door panels, to go in a poplar rail and stile frame, I am ordering one. The box setup we just installed last weekend, for bottom and top collection, works pretty well, and cost me over $100 to set up. This thing is almost foolproof and only $30 on Amazon. I will have one!
Amazon.com: Router Table Dust Collection Accessory: Home Improvement
Dick
Where there's a Willis there's a way!
Willway is offline
post #6 of 7 (permalink) Old 05-07-2014, 02:44 PM
First Name: Dick
Malcolm have you routed any heavy cuts in MDF? If so how did it do?
Dick
Willway is offline
post #7 of 7 (permalink) Old 05-12-2014, 06:03 AM
First Name: malcolm
I haven't routed MDF, but I have a shop full of routers mounted in tables. I have put the Keen product on the tables that create the most dust.
Newbie question about dust and chip control Harvey Dunn Table-mounted Routing 8 11-11-2013 09:56 PM
Dust Collection whimsofchaz Starting Off 5 08-20-2013 01:07 AM
Under table dust collection rbh11g Table-mounted Routing 7 02-21-2013 09:42 AM
Another hair-brained dust collection scheme Chris Curl Tools and Woodworking 27 12-08-2012 07:07 PM
Dust Collection Question deck99 Table-mounted Routing 7 04-25-2008 11:11 AM
