Jointing - Router Forums
post #1 of 5 (permalink) Old 06-04-2014, 01:37 PM Thread Starter
First Name: Martyn
Default Jointing
I have a project that I will need to joint some pieces that will be about 3.5 inches high, when sat on the narrow edge. I was contemplating using a bit that is 1.5 to 2 inch long and having an auxiallary fence with a height that would be equal to the bit length so the area that is not cut would not be bearing on the fence.
Am I asking for trouble in doing this or would it be safer way be to use a sled/ski setup?
Thanks.
Martyn
hprodcrx is offline
post #2 of 5 (permalink) Old 06-04-2014, 05:37 PM
Honored Member
First Name: pat
Definitely looking for trouble.
Limitations.
Quillman is offline
post #3 of 5 (permalink) Old 06-05-2014, 02:10 PM
Garyk's Avatar
First Name: Gary
could make you a carrier board to keep your fingers away from the cutter blades. Trying to surface small pieces is almost guaranteeing you a trip to the ER. After 50 years in woodworking my joiner is still the tool that scares the hell out of me. I always look for a way to keep my hands as far away from the blades as possible.
Garyk is offline
post #4 of 5 (permalink) Old 06-05-2014, 04:09 PM
Default Amen, Gary!
I'm with you on that!!
DaninVan is online now
post #5 of 5 (permalink) Old 06-06-2014, 05:16 AM Thread Starter
First Name: Martyn
Default I like my fingers!
I agree, I have a healthy respect for any piece of machinery after have worked as a machinist while going through college. The pieces are roughly 2 X 4 inches X 4-5 feet long. I would use finger boards the keep the piece against the fence and table on the infeed side and a push sticks and/or blocks to move it along and keep it tight on the outfeed side. I don't have access to a jointer or planer at this time and it's not in the budget for a while.
Martyn
hprodcrx is offline
Question Concerning Edge Jointing Jerry Bowen Tools and Woodworking 17 07-22-2012 11:55 AM
Other (Not Listed) VS600 Jointing system (dovetails etc.) allthunbs Festool Manuals 0 03-31-2011 02:38 PM
Jointing Bits CanuckGal Router Bits - Types and Usage 20 01-07-2009 10:02 PM
Router Jointing Drick General Routing 1 12-19-2005 09:21 PM
Jointing alternative? ktritz Table-mounted Routing 15 11-08-2004 03:22 PM
