Help oak tear-out - Router Forums
post #1 of 6 (permalink) Old 06-06-2014, 12:54 PM Thread Starter
no7
First Name: james
Default Help oak tear-out
I'm making raised panel cabinet doors using 3/4" oak. Using Bosch 1619 EVS router, speed setting #3, approx. speed 11,000 rpm, new MLCS router bits, Vertical Raised Panel bit 18 degree straight, Matched Rail and Stile 2 piece set Mission Style, Jessem Route R lift. Problem I've having is in routing the rails and stiles and the raised panels. Even though I'm taking four passes, I'm still getting tear out.
no7 is offline
post #2 of 6 (permalink) Old 06-06-2014, 05:12 PM
Semipro's Avatar
First Name: John_*
James, welcome to Router Forums, glad to have you join us, I'm positive the members of the community would be more than willing to answer any questions you have
Sorry I do not have the answer sounds like you are doing everything right
Thank You John
Semipro is offline
post #3 of 6 (permalink) Old 06-06-2014, 05:37 PM
First Name: Dick
Is your problem with cutting the end cut on the rails, or the raised panel cut??
Either way, do you have a backer board to protect the end of your cut?
dick in ia is offline
post #4 of 6 (permalink) Old 06-06-2014, 06:57 PM Thread Starter
no7
First Name: james
It's not on the end cut, I use a backer board with no problem. It's on the long cuts of the rail and stile and on the raised panel. Small intermittent tear outs along the way.
no7 is offline
post #5 of 6 (permalink) Old 06-06-2014, 10:47 PM
First Name: Dick
Two areas which might give you some help.
1st. Watch the grain direction of the board . Run the board so that the bit is cutting with the grain direction. Think which direction you would run a hand plain on the board and utilize the same technique. Also in this same area, it you see the cut has small ripples, slow down your feed rate slightly.
2nd. When making the long cut, I always do it in 2-passes. The first cut, I will hold the fence away from the bearing by a slight---app. 1/32", then finish with a light cut.
Good luck
post #6 of 6 (permalink) Old 06-07-2014, 09:45 AM
Garyk's Avatar
First Name: Gary
Sharp bits and Dick's suggestions should solve the problem. Any excess side movement of the piece during the cut will also cause the problem.
Garyk is offline
Outdoor untreated oak gates IAN1930 Project Plans and How To 7 04-14-2014 03:53 AM
Fenland Black Oak Table Project-5000 year old tree allbarknobite Lobby 6 10-18-2012 04:21 PM
raised panel oak cabinet doors bobshere Tools and Woodworking 7 01-13-2011 09:43 PM
Mounting an Oak Park Box Jig on Non Oak Park Table challagan Project Plans and How To 55 06-17-2009 11:18 PM
Oak, Octagonal Drum Table. derek willis Show N' Tell 18 02-25-2009 10:20 AM
