Need help, on Lip - Router Forums
post #1 of 10 (permalink) Old 06-12-2014, 03:50 PM Thread Starter
Default Need help, on Lip
Hello all I need some help on cutting a lip or rabbet,I have a 5 inch square 3/4 thick board ,I cut a 3-3/8 circle out in the middle of this board for a clock. but I need to rabbet out on the back side to 3-5/8 x 1/2" deep for the clock back to slide in to it but the fron side stays to the 3-3/8 opening,so what I need is a lip I guees you would call it.I have a router table,can this be done on it and how do I go about doing it,which router bit do I need to use
Thanks Bill
wumpabill39 is offline
post #2 of 10 (permalink) Old 06-12-2014, 04:38 PM
Semipro's Avatar
First Name: John_*
From the back side using a rabbet bit, be easier with hand-held router
Semipro is offline
post #3 of 10 (permalink) Old 06-12-2014, 06:33 PM
Exclamation
I agree, clamp the work piece and use a hand held router.
Sydney, Australia
jw2170 is offline
post #4 of 10 (permalink) Old 06-13-2014, 07:20 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Because I don't have any rabbet bits and I believe in the saying "necessity is the mother of invention", I would choose a decent sizes straight bearing bit like the one shown which is 3/4" and replace it's bearing with a smaller one and hey presto we have a rabbet bit! Because your clock to be has so little surface for the router to sit on I would use the ski mounted router as shown, the clock has of course to be firmly held on the bench, my favorite method is to pin pieces of scrap around the work-piece, the last two shots are typical of this method. It's a good idea to build up a selection of bearings, changing one can produce some very interesting variations from what a bit was intended for.
Here in pdf format is a photo-shoot showing how I make these skis.
Name:	pudding basin8.jpg
Name:	shed shelves0004.jpg
File Type: pdf The making of a set of router skis.pdf (1,001.8 KB, 55 views)
Harry
harrysin is offline
post #5 of 10 (permalink) Old 06-13-2014, 02:19 PM Thread Starter
Thumbs up Thank you
Thank you all for your reply's to my issue, and for harrysin, you gave me the best answer to my issue,I have many router bits but I did not have the proper size bearing to use for what I was wanting to do, I never thought of a Straight bit with a smaller bearing to do this with.so I thank you very much and I saved you .pdf file about the skis,I am going to build this ski item,question on using the ski, do you move the router along the rails or do you move the wood??
post #6 of 10 (permalink) Old 06-13-2014, 06:18 PM Thread Starter
Thanks all for the info. And for harrysin, your idea seems good, never thoght of using a straight bit.How does the ski work do you move the wood around the bit or do you move the router,I see it moves left and right how about front to back or in a circle?
post #7 of 10 (permalink) Old 06-13-2014, 10:32 PM
harrysin's Avatar
First Name: Harry
The router skis are operated from the end cheeks, this give a great deal of mechanical advantage, it gives the operator COMPLETE control of the router. For most operations the router is locked at the centre of the rails but there are occasions like when planing a board that is too wide for the skis to fully cover the surface, in which case the router is slid then locked over to one side then to complete the surface it is slid to the other end and locked. The attached photo. illustrates this.
Harry
harrysin is offline
post #8 of 10 (permalink) Old 06-13-2014, 11:15 PM Thread Starter
Hello harry,how do you make the Ski Rods do you have a .pdf on making them?
post #9 of 10 (permalink) Old 06-13-2014, 11:26 PM
harrysin's Avatar
First Name: Harry
Here it is! The diameter of the rods must of course match the holes in the router and the thinner they are the shorter they must be in order to prevent sag. Do NOT use Brass, it's too soft, it was the only 3/8" rod that I had at the time.
File Type: pdf Threading smooth rods for router skis without.pdf (517.8 KB, 31 views)
Harry
harrysin is offline
post #10 of 10 (permalink) Old 06-13-2014, 11:30 PM Thread Starter
Thank you Harry, you have made my day with routing,the answers you gave me works great,you have inspired me to use my router more, I like to use the router table a lot making trim of all kinds
Routing a lip on a box or the back of a picture frame after it has been glued up Harvey Dunn General Routing 1 05-16-2014 12:37 PM
I've realised why the forum has been quiet the past few days harrysin Lobby 16 06-09-2012 06:28 PM
Rebate lip for plate and cutting radius gregmw Table-mounted Routing 10 12-26-2009 02:06 PM
Dumb Question Melvin Table-mounted Routing 15 11-18-2009 08:06 AM
Lid Lip RichB New Member Introductions 6 01-03-2006 06:08 PM
