UJK Plate Insert Rings. - Router Forums
post #1 of 2 (permalink) Old 06-14-2014, 11:12 AM Thread Starter
Rogerdodge's Avatar
First Name: Roger
Default UJK Plate Insert Rings.
Well I successfully built my Router Table ( lots of help on here , for which much thanks .) I used a 6mm Aluminium Plate by UJK. My question is about the centre insert rings.The one which came with the plate has a hole of about 35mm which is fine as far as it goes but I am looking for more sizes. Nobody here in the UK seems able to supply the set of four which UJK advertise. ( Axminster have been out of stock for a while.) These are twist lock inserts around 90mm in diameter.
Does anyone on here know where to get these insert rings from or whether any other makes are compatible ( Woodpecker , Jessem, Kreg etc. ?)
Rogerdodge is offline
post #2 of 2 (permalink) Old 06-24-2014, 12:18 PM Thread Starter
Rogerdodge's Avatar
First Name: Roger
Like Hen's Teeth these were ! So much so I was tempted to fit some instead. I did eventually find the correct rings in one of Axminster's shops . ( Very helpful they were too.)
Arrival of said reducing rings is now imminent , but don't expect any wip pics as I fit them to the table.
Rog
Been at sea most of my life and still all at sea now.
Sometimes I sits and thinks and sometimes I just sits .
(M Twain)
adding rings to router plate Goblu Table-mounted Routing 10 05-14-2014 11:20 AM
For Sale: Kreg router plate insert with level loc rings Ducmon Woodworking Classifieds 2 03-28-2014 04:11 AM
Samona Insert Plate bill0199 Table-mounted Routing 9 01-06-2012 02:30 PM
For Sale: Woodhaven 147 Large Insert Plate - $25 oldhippie1951 Woodworking Classifieds 0 08-16-2011 05:55 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
