Buncha Questions - Router Forums
post #1 of 5 (permalink) Old 06-21-2014, 11:25 AM Thread Starter
JohnnyRelentless's Avatar
First Name: Darren
Default Buncha Questions
I am new to woodworking and the router in particular seems like a strange and mysterious, potentially awesome new tool. I already used it with a sled I built to 'plane' my workbench surface. But now I want to build a router table with a split fence, miter slot, and dust collection.
I have:
Ryobi Model # RE180-1PL 2hp plunge router.
MLCS 9338 All-In-one Router Plate Kit
Professional Woodworker 7744 router bit set
48" T slot
3/4" plywood.
The router insert plate didn't come with any instructions and after wearing out my google machine trying to understand routers in general and router tables in particular, I still have some questions.
1. The instructions I keep finding say to remove and replace the router base plate before mounting to the insert plate. Why? My router doesn't seem to have a removable base plate, although it did come with 2 screws that fit through 2 threaded holes in the base of the router. Couldn't I just drill 2 holes in the insert plate and mount the router directly, or do I need to add a base plate in between?
2. If I need a base plate, how do I know if a given base plate will fit my router? Some say they are universal, but I still have doubts as to whether or not they will fit a Ryobi plunge router. Should I just make a base plate myself?
3. What is the purpose of the base plate? What do I want it to do?
4. If I get a guide bushing, does it mount to the insert plate or to the router base plate?
5. How important is precise centering of the router onto the insert plate? Is it only important if I use guide bushings? Should I order the guide bushings and centering pin before I assemble the table? Is centering that important?
6. Unlike a table saw, I am thinking that a router table fence doesn't need to be particularly square to anything, am I right? Simple clamps or T slots should be sufficient to secure it.
JohnnyRelentless is offline
post #2 of 5 (permalink) Old 06-21-2014, 01:53 PM
RainMan 2.0's Avatar
This is the question I'm most curious about . To me , if there's a miter slot for mitering or feather boards then it's critical . It will be interesting to see what the answer is . Sorry I can't be of much help , but I'm sure the experts will jump in soon.
It concerns me as when I build a RT I'm hoping I get get the miter slot within a Rickameter
RainMan 2.0 is offline
post #3 of 5 (permalink) Old 06-21-2014, 02:09 PM
Marco's Avatar
Darren there are a couple of threads specific to your questions. Some members may have those threads at there finger tips and direct you to them.
As for #2 #3 and #4. I recommend Milescrafts base plate and their bushings that easily are changed. Milescraft 1211 Base Plate Metal-Nose Bushing Set for Routers - Power Router Accessories - Amazon.com Plus with out the bushings there is a big opening in the plate so you can see the bit. Good luck.
[BďItís not a mistake, itís a design featureĒ][/B]
Marco is offline
post #4 of 5 (permalink) Old 06-21-2014, 02:15 PM
First Name: del
I have:
48" T slot
3/4" plywood.
# 5 on the centering of the router table , not that important because the fence can be set across the bit at most any angle as long as you stay on the left side of the bit and feed into the rotation of the bit , not if doing plunge the bit should be centered with the center pin, if doing percise cutting,
#4 the bushing i use doesn't have anthing on it other than making the hole to fit the bit's and making the hole smaller
#2 the plate that goes into the router table fit's on the router, you take off the router base place and screw router to the base plate,
here is the router table i have, it is not for sale any longer , no need for a T track and all that fancy stuff, look at the table all that is needed is the fences , their are 3 of them but not avaible now , you mite post and see if any one may some that they would part with, you can make them your self tho , i will post the picture of the router work shop unit and look at it , you will get the idea of what a good table looks like good luck the picture is small if you have a wheele on your mouse you can hold down CTRL while you rotate the wheel it will make the picture bigger if it get smaller go the other eay
del schisler
port st. lucie, florida
del schisler is offline
post #5 of 5 (permalink) Old 06-21-2014, 07:07 PM
If you go to the forum homepage you'll see all the categories that are on the forum. If you click on them a list of "sticky threads" will come up, among other things. These are on subjects that we see questions about on a regular basis. Here is one of those sticky threads about mounting a router on a plate. http://www.routerforums.com/table-mo...ing-plate.html
Questions - questions - questions Digby New Member Introductions 15 03-04-2013 06:12 AM
General questions about CNC routers / options MakingDust CNC Routing 23 09-23-2012 07:50 AM
Jasper Model 274 Random Noob Questions nwsalmon Jigs and Fixtures 3 03-06-2011 09:00 AM
No questions in this section! Mark Router Reference 0 06-08-2008 12:59 AM
Crossword Puzzle with BJ's questions BobandRick Site Help and Suggestions 0 02-01-2007 01:16 PM
