trouble installing Grizzly Plate - Router Forums
post #1 of 1 (permalink) Old 07-01-2014, 09:18 PM Thread Starter
chessnut2's Avatar
Default trouble installing Grizzly Plate
Hello all. Hope everyone's doing well. I finally got started building a router table with a Grizzly insert plate. I don't have a router that uses guide bushings, so I made a template to flush trim the hole once I sawed it out.
I was planning to make another template for routing the rabbet where the lips of the plate rest on the top of the table. I figured that a 1/2" rabbet bit wouldn't make a sharp enough radius at the corners, so I would use a template to guide the router with a 1/2" straight bit installed.
Then I realized that the 6" or so router base might cause the corner radius to be a lot less sharp than even the rabbet bit would. Does this sound logical?
I must have missed something about this issue in all the previous discussions about plate mounting. Do you chisel out the corner if the radius isn't small enough? Do you freehand it? Or would my first thought about using the router with the template for the rabbets work? Thanks. Jim
chessnut2 is offline
Grizzly T10432 Router Table Plate (@#$%^) IC31 Table-mounted Routing 21 12-23-2014 02:57 AM
Triton Router - Grizzly Router Plate. Warping? Dust Devil Table-mounted Routing 8 02-03-2014 11:44 AM
Trouble mounting Router to Plate grumpyguy Table-mounted Routing 5 04-01-2013 11:11 AM
Grizzly Router Plate planbbob Table-mounted Routing 18 10-22-2012 01:35 PM
