Round over bit set up. - Router Forums
post #1 of 9 (permalink) Old 07-05-2014, 01:51 PM Thread Starter
First Name: Al
Default Round over bit set up.
Is there a simple method for setting the height of a round over bit, particularly the small ones, !/8 1/4 etc, without getting a shoulder and having to use trial and error raising or lowering the bit a dozen times or more to get rid of it ? Thanks Oldrusty
oldrusty is offline
post #2 of 9 (permalink) Old 07-05-2014, 02:52 PM
Trial and error works for me!
I usually try and start with the smaller cut and work up to the cut +shoulder, then back off a tich.
DaninVan is offline
post #3 of 9 (permalink) Old 07-05-2014, 03:14 PM
Same as Dan. You usually need to sand a little anyway so a very tiny bit of shoulder or a very tiny bit of sharp curve is usually of no consequence. I can usually sight across the sole plate of the router and get it close enough.
post #4 of 9 (permalink) Old 07-05-2014, 03:29 PM
Gaffboat's Avatar
First Name: Oliver
I'm with Dan and Charles. I use the same methods. It's not as much work as you think, I usually get what I want with one or two test cuts. You can use a piece of scrap and only have to rout enough of a roundover to check it. (Less than an inch of the edge.)
Gaffboat is online now
post #5 of 9 (permalink) Old 07-05-2014, 03:29 PM
paduke's Avatar
Amen Charles
Spend a minute sanding or 5 dialing in?
paduke is offline
post #6 of 9 (permalink) Old 07-05-2014, 06:42 PM
Agreed Bill. A roundover is very, very rarely that critical.
post #7 of 9 (permalink) Old 07-06-2014, 07:05 AM
richjh's Avatar
First Name: Rich
I use the edge of a 6" stainless steel ruler and bring the outer edge of the bit until it just meets the edge of the ruler that I'm holding flat on the table.
Basically, a tool is an object that enables you take advantage of the laws of physics and mechanics in such a way that you can seriously injure yourself - Dave Barry
richjh is offline
post #8 of 9 (permalink) Old 07-06-2014, 11:35 AM
Rich; yes, but I use a plastic straightedge as I'm paranoid about bringing metal into contact with the carbide cutting edge. Probably no validity to my concern?
DaninVan is offline
post #9 of 9 (permalink) Old 07-06-2014, 07:30 PM
paduke's Avatar
I use an aluminum straight edge for set up 1/8 x 1" x12" it also is used for measuring and layout It is softer than carbide. Quillman mills aluminum with router bits so I am not worried about nicking my bits
paduke is offline
In need of a tongue and groove bit set... BigCountry Router Bits - Types and Usage 31 04-14-2014 08:01 PM
PC cove router bit set routafinger The Bargain Bin 1 01-02-2011 03:05 PM
Bosch Ogee Rail and Stile Bit Set setup? gxbluewave Table-mounted Routing 1 01-07-2008 09:45 PM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
