1/4 inch collet triton router - Router Forums
 4Likes
post #1 of 21 (permalink) Old 03-15-2015, 05:24 PM Thread Starter
First Name: Chris
Unhappy 1/4 inch collet triton router
I am feeling pretty stupid but I can't fiqure out how the 1/4 collet goes on bushing on Triton Router. The insert within the collet seems too large to fit into bushing? What I am missing. Thx.
Chris
Acworth,GA
chris kenney is offline
post #2 of 21 (permalink) Old 03-15-2015, 07:46 PM
Chris, I may be getting the terminology confused....
Do you have a separate 1/4" collet or a 1/4" insert that goes into a 1/2" collet.
I think of a bushing as a guide bushing that attaches to the base plate.
Understanding Guide Bushings
Sydney, Australia
jw2170 is offline
post #3 of 21 (permalink) Old 03-16-2015, 05:42 AM
kywoodchopper's Avatar
First Name: malcolm
Hi Chris, my Triton has separate collets for 1/2" and 1/4" bits. On mine, I just unscrew the 1/2" collet and screw in the 1/4" collet. I know we men don't like to do this, but if there is a manual see if there are pictures to follow. Also, whenever I install any router bit I tug on it to make sure it is secure prior to starting the router. Malcolm / Kentucky USA
kywoodchopper is offline
post #4 of 21 (permalink) Old 03-16-2015, 07:31 AM Thread Starter
First Name: Chris
James--I have a Collet with an internal "floating" socket. The internal socket "seems" to large to fit into open chuck in the router? Thx for previous reply.
Chris
post #5 of 21 (permalink) Old 03-16-2015, 07:33 AM Thread Starter
First Name: Chris
Malcolm--thx for reply--see my post to James? Thx.
post #6 of 21 (permalink) Old 03-16-2015, 07:35 AM Thread Starter
First Name: Chris
James--a separate collet with internal insert
post #7 of 21 (permalink) Old 03-16-2015, 09:31 AM
harrysin's Avatar
First Name: Harry
These shots show the collet removed from the lower chuck, what it looks like with a bit secured and three sizes of reducer sleeves. Perhaps these shots will help you to explain clearly what your problem is.
EDIT: I see that the forum is still duplicating photographs.
Harry
harrysin is offline
post #8 of 21 (permalink) Old 03-16-2015, 01:18 PM
fredrocks's Avatar
First Name: Fred
Default This is my TRA001
Hello all. This is my first post, but I have a Triton so I thought I would jump in. The first picture shows the 1/2 inch and 1/4 inch collets upside down next to bits that go into them, and the other two pictures show them installed. I hope this helps you out Chris.
fredrocks is offline
post #9 of 21 (permalink) Old 03-16-2015, 03:20 PM Thread Starter
First Name: Chris
Fred and everyone else-thx for trying to help. Fred's picture is what I have with an exception. There is no collet inside my threaded 1/2 inch collar. I am a new woodworker so I may have confused the issue with wrong terminology. And the manual I have does not have one mention of this part of machine. So then, the collet must be already mounted on the bit holder. If so, i will have to remove the collet already mounted. before I destroy something--what is procedure for this??
Chris
post #10 of 21 (permalink) Old 03-16-2015, 04:15 PM
Forum Moderator
MT Stringer's Avatar
Chris
Got any pics of your stuff?
I know this sounds pretty dumb, but are you sure that is the correct collet for the Triton? I have a pair of Bosch's along with the Triton.
MT Stringer is offline
Triton 3 1/4 HP Router chris kenney Table-mounted Routing 1 03-15-2015 08:45 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Triton in table - collet quesion JP Wolf New Member Introductions 6 08-17-2014 09:28 PM
Problem with installing 1/2 inch bits in new Triton 2 1/4 router roofner General Routing 14 06-04-2013 01:54 AM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
