Brackets to mount a table top? - Router Forums
post #1 of 11 (permalink) Old 11-21-2007, 11:51 AM Thread Starter
Nickbee's Avatar
Default Brackets to mount a table top?
I saw some metal brackets on a post here somewhere. Canít seem to dig them up. They fitted into slots on the sides then screwed up into the bottom of the table. Where can one get these things? Do any of the box stores carry them? Or is this a net item?
Thanks!
Nickbee is offline
post #2 of 11 (permalink) Old 11-21-2007, 12:08 PM
First Name: Doug
DougO is offline
post #3 of 11 (permalink) Old 11-21-2007, 12:14 PM Thread Starter
Nickbee's Avatar
Yup that's it,, can I get those at a box store?
Nickbee is offline
post #4 of 11 (permalink) Old 11-21-2007, 12:18 PM
Drugstore Cowboy's Avatar
Dunno about that -- but Woodcraft has them in boxes of 10
for .50 less :-)
http://www.woodcraft.com/family.aspx...e=details#tabs
As for the big boxes ----
My guess would be - no - but sometimes they surprise me.
You would want to look in a couple of places --
In the regular 'hardware' aisle with the hinges and clasps etc -
But then also go over to where they have the precut table tops etc.
You just might find them in amongst the bolts and brackets for attaching legs.
Good luck.
The one who says it can't be done --
Should avoid interrupting
the person doing it.
Drugstore Cowboy is offline
post #5 of 11 (permalink) Old 11-21-2007, 12:38 PM
Hi Nick
The picture you recall was from Harry (view gallery)
But this is one item you can make and they are easy to make on the table saw or the router table,,,I make about 50 or so at one time they do come it handy, I keep them in a plastic bag until it need about 8 for a table top..
Thanks!
Name:	table top hold down.jpg
Name:	corner block.jpg
post #6 of 11 (permalink) Old 11-21-2007, 01:12 PM
Roefa's Avatar
First Name: Roger
Send a message via Yahoo to Roefa
I have made my own for two projects using standard metal angle brackets from the hardware store. You'll need a good hefty vise, hack saw, hammer and a grinder or file to remove the sharp burrs and corners. Don't try for sharp 90 degree bends; they'll break! A soft bend works just fine... just get the height right. I wouldn't mind buying them on the internet, but I'm usually too impatient to wait on the shipping, and it would never occur to me to plan ahead! Ha!
Roger
(Roefa)
Thinking outside the box? What box?
Roefa is offline
post #7 of 11 (permalink) Old 11-21-2007, 01:24 PM
Hi Roger
A hand propane torch works great to heat them up for bending,,,just get it to turn red and hit with the hammer and they will come out with a square corner bend..
PLus use a scratch awl or nail works great for marking the bend line..
Just about ever one has a propane torch ...
post #8 of 11 (permalink) Old 11-21-2007, 02:09 PM
First Name: Charlie
I've used these...
reikimaster is offline
post #9 of 11 (permalink) Old 11-21-2007, 03:40 PM
challagan's Avatar
Originally Posted by bobj3
Hi Nick
Norm Abrams uses this system all the time similar to what BJ posted. Pretty quick and easy to make with scrap.
http://iowacarver.tripod.com/
challagan is offline
post #10 of 11 (permalink) Old 11-21-2007, 04:28 PM Thread Starter
Nickbee's Avatar
I'm going to be making another trip to woodcraft soon (what a fun store)... I'll see if they have them in stock at the store!
Nickbee is offline
Mount DW618 in Table Saw acess. or build my own? GaryA Table-mounted Routing 6 04-06-2010 01:41 AM
Cutting shelf brackets on table? Birch Table-mounted Routing 35 04-19-2007 12:03 PM
Best Way to Mount Table to Base? saddlesore Table-mounted Routing 4 04-14-2007 03:39 PM
Hitachi M12V table mount questions vwmowery Table-mounted Routing 7 10-04-2006 06:53 PM
Table mount routers... Bluegillman General Routing 1 12-02-2004 09:37 AM
