Those OP style poly fences..... - Router Forums
post #1 of 4 (permalink) Old 12-16-2007, 04:07 PM Thread Starter
Default Those OP style poly fences.....
....is there anywhere I could buy a 2 5/8" one like on OP's raised panel jig? On the OP site they only seem to have the 1 7/8" ones....
...unless, someone has a better solution:
I have this big multi-purpose bit that does not fit in the standard router fence, and I would like to be able to use the bottom of it as well as the top. Safely. I figured I would get a fence and cut a hole big enough for my bit to fit, but with the 1 7/8" I would only be left with 1/4"-3/8" material on the back of the fence...
tpyke is offline
post #2 of 4 (permalink) Old 12-16-2007, 04:15 PM
challagan's Avatar
Well the easiest thing would be to make one out of wood to do the same thing. If you have a jointer you can get a real nice one out of a 2 x 4 that would work the same way. Otherwise I don't know where you can get poly like that and it's fairly expensive.
http://iowacarver.tripod.com/
challagan is offline
post #3 of 4 (permalink) Old 12-17-2007, 08:33 PM Thread Starter
Great idea!!!!
I just got it done...I had an old piece of 2X4 lying close to the fireplace for a little over a year now, so I'm pretty sure it's dried up. No jointer, so I took a little bit off of every side of the 2X4 on my bench saw until it was straight all around, chamfered the edges, routered out the hole.
I'm having a blast just getting this router table setup
tpyke is offline
post #4 of 4 (permalink) Old 12-17-2007, 09:42 PM
challagan's Avatar
LOL.... glad to hear it worked out!
Poly the inside of furniture? WoodyRon The Finishing Touch 4 09-11-2007 08:28 PM
Poly. Cutting Boards bobj3 Show N' Tell 4 08-17-2007 11:06 PM
fences Jerryw New Member Introductions 5 07-23-2007 12:14 PM
Easy Source for high density poly fences Svideo Table-mounted Routing 1 03-27-2007 10:53 PM
Router Table Fences curiousgeorge Table-mounted Routing 12 01-27-2007 11:56 PM
