When making panels... - Router Forums
post #1 of 5 (permalink) Old 12-19-2007, 04:45 PM Thread Starter
Default When making panels...
do you guys make multiple passes to reduce wear on the router and the bit? Twice now I've read about this. I've only cut into pine and cedar so far with my panelling bit and it went through with no problem at all. Should I be more careful if ever I deal with harder woods?
tpyke is offline
post #2 of 5 (permalink) Old 12-19-2007, 06:07 PM
Just don't bite off more than you can chew.
yetiatlarge is offline
post #3 of 5 (permalink) Old 12-19-2007, 10:03 PM
curiousgeorge's Avatar
First Name: George
With the larger paneling bits you need to take smaller bites. It's safer, puts less strain on the bit, you will get a lot smoother cut and less tear out with more passes. Even in soft woods and Especially in harder woods.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #4 of 5 (permalink) Old 12-20-2007, 05:44 PM
When I need help with taking big bites, Yeti just jumps in and chews it up.
post #5 of 5 (permalink) Old 12-20-2007, 07:21 PM
challagan's Avatar
I would always make at least 2 passes. Even if you can get it done in 1 pass, do it in two and make the last past a real fine pass to give a nice smooth finish.
http://iowacarver.tripod.com/
challagan is offline
Is there quick fix for slightly loose fitting raised panels? tpyke General Routing 4 06-16-2010 07:12 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 07:20 PM
Making a vase part 1 chippypah Woodturning and Lathes 0 03-04-2008 02:23 AM
Question about raised panels tpyke General Routing 4 01-29-2008 01:40 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
