Bosch Ogee Rail and Stile Bit Set setup? - Router Forums
post #1 of 2 (permalink) Old 01-07-2008, 07:11 PM Thread Starter
Question Bosch Ogee Rail and Stile Bit Set setup?
I bought this bit set from a friend who never used it. The only problem is that he lost the setup sheet for the bits. As I have never done any panel work and want to build some inexpensive doors for my garage cabinets, I thought I would use these bits to add a little extra trim look rather than just tonge and grooved insets. Can someone tell me how to reference the height on the stile bit once I have cut the rail? I am not sure what cutting edge I must reference the height to and since I will be using a coping sled, I really am not sure other than burning up a bunch of wood to build some set up template blocks.
Any help would be appreciated.
gxbluewave is offline
post #2 of 2 (permalink) Old 01-07-2008, 09:45 PM
Hi gxbluewave
I would Recommend going to the link below and take a look around, you will see 30 or so of videos,,
http://www.woodworkingonline.com/category/podcast/
http://www.woodworkingonline.com/cat...odcast/page/2/
http://www.woodworkingonline.com/cat...odcast/page/3/
http://www.woodworkingonline.com/cat...odcast/page/4/
Cabinets,panels,many,many more,great group of show and tell videos,, you will say the same as I , WOW
Also see PDF file below ▼
Rail and Stile alignment....HELP arkwood Router Bits - Types and Usage 15 07-11-2011 05:16 PM
Hi all -- rail and stile bit and 1/2" collet help! Bryan Router Bits - Types and Usage 16 03-31-2009 10:28 PM
Stile & Rail Bit DougO Router Bits - Types and Usage 7 07-11-2007 08:42 PM
Rail & Stile Dilemna [email protected] Table-mounted Routing 3 01-22-2007 02:49 PM
Stile and Rail setup? fitz Jigs and Fixtures 1 03-26-2005 07:53 AM
