Pattern routing problems - Router Forums
post #1 of 7 (permalink) Old 01-29-2008, 09:53 AM Thread Starter
Default Pattern routing problems
I have recently started making Crosses for my Mom's craft business and am using the patterns she has used in the past. She always cut them by hand and sanded. Each one took a long time. I am trying to rough cut the pattern and rout the shape with a flush trim bit. I always get shattering and the wood gets slapped around a lot on the table. I even spent $40 on a spiral cutting flush trim bit to see if that would help. Any suggestions on what I am doing wrong?
Interdesk is offline
post #2 of 7 (permalink) Old 01-29-2008, 10:34 AM
Hi Interdesk
You may want to use a template and a brass guide in your router table,or a pattern bit..
The pattern bit has the bearing on the bottom part of the shank under the cutters so it can ride on the pattern,,,the brass guide and the pattern bit will let you get on and off the template easy, to start and stop a new pass.
This is true when you are going up hill on the grain/cross the grain of the stock..(Crosses)
Your template can be 1/2" or 1/4" MDF thick stock or plastic,hardboard but not plywood..
This type of template works best in the book type/sandwich type, jig,, and a hold down clamp to hold it in place , then just do one side then flip the stock around and do the other side,,,this will give you something to hold on to..
shattering
# To cause to break or burst suddenly into pieces, as with a violent blow.
1. To damage seriously; disable: His health was shattered by the disease.
2. To cause the destruction or ruin of; destroy:
post #3 of 7 (permalink) Old 01-29-2008, 12:26 PM
cabinetman's Avatar
First Name: mike
WELCOME TO THE FORUM Interdesk
If you are using a 1/2" flush trim bit with a bearing you might try going down to a 3/8" flush trim with a bearing. It takes a lesser chunk out and may be easier to control, giving a better cut.
cabinetman is offline
post #4 of 7 (permalink) Old 01-30-2008, 02:11 PM
Hi Interdesk
Here's some Crosses you may want to look at...
post #5 of 7 (permalink) Old 01-31-2008, 10:21 AM Thread Starter
Thanks Bob! Are those done on the machine in your icon?
post #6 of 7 (permalink) Old 01-31-2008, 10:28 AM
Hi Interdesk
The 3rd. picture I have done with the machine but the others are just snapshots
of a cross...
post #7 of 7 (permalink) Old 06-05-2013, 07:52 PM
doug12's Avatar
First Name: Doug
Make a couple of patterns out of 1/2 MDF. Use a scroll saw or jigsaw. Then get a good template guide that fits your router correctly. Use a 1/4" Solid Carbide Spiral UpCut bit to cut your design from the wood you are using for your product using you new template. Be very careful, you must hold tight and start your upcut bit at a 45% angle and sink it into your product material (wood) until your router base is level on your template. Then move your router with the upcut bit in it toward your template. Make sure your template guide is tightened down well so it doesn't vibrate loose!!!
doug12 is offline
Routing Template Verlin Garrett Jigs and Fixtures 16 08-17-2019 09:12 PM
Introduction and questions re: kickback problems BrettW New Member Introductions 2 05-05-2008 07:56 PM
Dust Colection for routing Dados KentWW Table-mounted Routing 3 01-10-2007 02:18 PM
pattern routing JJ101 General Routing 2 04-15-2006 06:00 AM
Pattern routing curves kak047 Jigs and Fixtures 6 11-03-2004 02:31 AM
