adjustable out fence? - Router Forums
 20Likes
post #1 of 23 (permalink) Old 07-16-2015, 11:10 AM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Default adjustable out fence?
In my never ending search for a way of getting very straight edges to small pieces of wood, has any one got or know of an adjustable out feed fence, so I can use the router table as a sideways planer?
Seems to me to be a gap in the market here, or is there something I dont know which will make the idea unworkable?
sunnybob is offline
post #2 of 23 (permalink) Old 07-16-2015, 12:47 PM
First Name: 4D
I will use a router table for jointing the edges of boards and it doesn't require a fancy fence.
I'll usually use a spiral end mill for smoothest results.
Use any straight fence. One the outfeed side simply stick one (or more) layers of blue (or green) tape. Set the edge of the bit flush to the taped side.
When done, peel the tape off.
MT Stringer, ksidwy and Roy Drake like this.
4DThinker is offline
post #3 of 23 (permalink) Old 07-16-2015, 01:08 PM
Bob, build this simple fence and cut 1/32" or 1/16" off the leading edge. You get dust collection too.
Name:	Fence bottom.JPG
MT Stringer, hankh and ksidwy like this.
post #4 of 23 (permalink) Old 07-16-2015, 01:23 PM
PhilBa's Avatar
First Name: phil
There definitely are plans out there for such a fence. Given that you only need a very small amount of offset (1/16" or so), 4D's tape approach or similar makes a lot of sense. Not having to worry about the fence being 100% straight makes a split fence somewhat undesirable.
PhilBa is offline
post #5 of 23 (permalink) Old 07-16-2015, 01:24 PM
In my uploads is a picture of the last fence I made. It was fairly simple to build and had moveable and shimable faces. You can shim the outfeed side for jointing. Plastic playing cards make excellent shims. They are very uniform in thickness. I liked the fact I could close the gap around the bit. It made me feel a little safer even though I have quite a few years experience using routers and router tables.
post #6 of 23 (permalink) Old 07-16-2015, 01:28 PM
This is the first fence I built from the plans in ShopNotes #1. A thin piece of plastic or HPL dropped behind the out feed face does the trick.
"Keep it simple"
whimsofchaz and ksidwy like this.
post #7 of 23 (permalink) Old 07-16-2015, 01:31 PM Thread Starter
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I have a split fence, with extraction, which works quite well to keep the cutter gap as small as possible, but i just tried packing out the out feed and got a small snipe on the cut face as the wood pressed into the out fence, and a bigger snipe at the end.
Did I just not measure well enough?
are feather boards necessary on this operation? i'm just using push sticks.
sunnybob is offline
post #8 of 23 (permalink) Old 07-16-2015, 01:57 PM
Keep pressure against the in feed side of the fence until you have to switch to the out feed side.
post #9 of 23 (permalink) Old 07-16-2015, 05:50 PM
Honored Member
First Name: pat
More on this.
Would keep the waste to <1/32"/pass. Jointing is aggressive and the router and cutter
take a heck of beating here. Jointing should be left to the jointer.
One exception: Those materials that require carbide.
Mike, Stargate and Herb Stoops like this.
Quillman is offline
post #10 of 23 (permalink) Old 07-16-2015, 06:40 PM
I have fallen out of my share of trees Pat.
Laguna TSS. MAFoElffen Tool Reviews 12 08-12-2017 10:30 AM
Kreg Precision router fence #PRS1010 TwoSkies57 Table-mounted Routing 2 06-29-2013 12:45 PM
Homemade adjustable router fence. NewMontanaWorkshop Jigs and Fixtures 17 06-13-2012 10:12 AM
A Poor Man's adjustable Positioning Fence Stefang Table-mounted Routing 8 02-26-2010 03:22 AM
