Creating angled slots - Router Forums
post #1 of 3 (permalink) Old 02-02-2008, 07:05 PM Thread Starter
First Name: Dennis
Default Creating angled slots
I'm attaching a sketch that will show what I want to do. Can you advise what would be the best way to create the slots.
Thanks...Dennis in Boise
Name:	Whist card holder.jpg
Dennis Davis is offline
post #2 of 3 (permalink) Old 02-02-2008, 07:44 PM
Dennis, The easiest way I can think of is to use door shims under the edge to tilt the work piece to the angle desired for the first cut, make your pass and then re-shim for the 2nd angle and make your pass. This is a job where using a router in ski mode pays off. You will find easy plans to make a ski jig for your router in the templates and guide bushings section.
post #3 of 3 (permalink) Old 02-02-2008, 08:38 PM
Hi Dennis
This is one job that can be done on the table saw and it would be easyer..
I would start over,,,yep I know
1st. put in the slots for the cards then rip to size then put on the end caps this will hide most of the end grain then round over the card holders...
Use what you have now and rip the card slots and then glue on the Maple end caps and then round them over to match what you now have made...
Just a note**** to keep the slot thin, you can get 6 1/2" saw blades that are 1/16" or 3/32" thick ....they also work well for cutting plywood on the table saw...
see item below
Name:	card holder.jpg
Looking for Jig to Cut Key Slots with Slot Cutting Bit jimcrockett Jigs and Fixtures 8 06-27-2008 08:45 AM
cutting slots Grandpasworkshop General Routing 4 10-22-2006 06:59 PM
making an angled tray falcn63 Table-mounted Routing 5 05-19-2006 02:10 PM
Slots for hand screw clamps Woofman Jigs and Fixtures 11 02-11-2005 07:24 PM
Routing stopped slots jarhead Portable Routing 7 11-05-2004 08:47 AM
