Small raised panel for a box - Router Forums
post #1 of 20 (permalink) Old 02-11-2008, 08:15 PM Thread Starter
First Name: Steve
Default Small raised panel for a box
I would like to make a box with a raised panel in the lid. I know you can make these on a table saw but I would like to do one with a router and without a lot of complication.
Could you just use a portion of a vertical panel raising bit?
Dumb question probably.
Steve Bolton
Name:	raised panel.jpg
S Bolton is offline
post #2 of 20 (permalink) Old 02-11-2008, 08:23 PM
Hi SB
" Dumb question probably" = NOT
Yes and it's easy to do and very safe
see my Gallery if you want a tip or two for the jig..to do it..
You can also do it without the jig if you want to..
Steve Bolton
post #3 of 20 (permalink) Old 02-11-2008, 08:49 PM Thread Starter
First Name: Steve
Bob, I can't find it in your gallery because you have a huge gallery and I am not sure how to find what you are directing me to. Can you direct me there?
Steve Bolton
S Bolton is offline
post #4 of 20 (permalink) Old 02-11-2008, 08:59 PM
Hi SB
Here's a link or two that should help
http://www.routerforums.com/jigs-fix...uick-easy.html
http://www.routerforums.com/show-n-t...4-new-toy.html
post #5 of 20 (permalink) Old 02-11-2008, 09:14 PM Thread Starter
First Name: Steve
Bob, I think the horizontal table would be the way to go. I don't know how thick the raised panel stock would be. I wonder if I would need to use one of these.
SB
S Bolton is offline
post #6 of 20 (permalink) Old 02-11-2008, 09:25 PM
Hi SB
You can but you don't need to , lets say if you use 5/8" thick stock or just remove the stock from the front side of the panel until you have 1/4" thick on the side/edge of the panel..
Many ,many ways to make raised panels..
You can also use a rabbit bit or just about any router bit to do the same job ...as the one you posted, but it will be a square cut..
And you'er right the Horz.table is the easy way to make square cut panels...It takes less than 2 mins to make one...from start to finish....
post #7 of 20 (permalink) Old 02-11-2008, 09:27 PM Thread Starter
First Name: Steve
Or would this be ok for a raised panel on small wood? It doesn't have the usual flattened area that goes inside the groove.
SB
Name:	Ok for raised panel.jpg
S Bolton is offline
post #8 of 20 (permalink) Old 02-11-2008, 09:37 PM Thread Starter
First Name: Steve
It would look like No. 2, not No. 1. Okay?
S Bolton is offline
post #9 of 20 (permalink) Old 02-11-2008, 09:40 PM
HI SB
True
They make many types of Vert.Router bits to get what you want to end up with..
http://www.mlcswoodworking.com/shops...ter_bits2.html
SB
Name:	panell horz..jpg
post #10 of 20 (permalink) Old 02-11-2008, 10:07 PM Thread Starter
First Name: Steve
Did you do those using paint net? That is neat.
So, no mechanical problem with this one? Expansion/contraction?
sb
Name:	no problem with mechanics of this joint.jpg
S Bolton is offline
Vertical Raised Panel Question rprice54 General Routing 23 03-14-2014 11:29 PM
Raised Panel Vertical or Horizontal Sets? WoodyRon Router Bits - Types and Usage 8 11-24-2007 02:54 PM
Raised Panel Bit rmaxa Router Bits - Types and Usage 3 09-13-2006 09:56 AM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
research for raised panel doors presumed_druid Table-mounted Routing 4 01-13-2006 10:47 PM
