Power feed on RT - Router Forums
 2Likes
  • 2 Post By Mike
post #1 of 5 (permalink) Old 08-02-2015, 05:35 AM Thread Starter
paduke's Avatar
Default Power feed on RT
I am contemplating adding a power feed (delta 1/4 hp) to my table. I have been making my own architectural moldings (baseboard, door casing, chair rail etc). I do multiple passes with a 32'nd final pass for clean up. Then I sand out the blips and chatter marks.
Will a power feeder improve my results?
paduke is offline
post #2 of 5 (permalink) Old 08-02-2015, 05:50 AM
all a power feeder does is feed ...
you do the set for everything else...
you doing this for a shaper???
post #3 of 5 (permalink) Old 08-02-2015, 07:50 AM Thread Starter
paduke's Avatar
No as stated in thread title on an rt.
I believe the feed stabilizes the cut as opposed to irregular pressure from featherboards and inconsistent feed rate.
I recently made crown molding from ash to match my cabinets. My initial pass was 1/8" then 1/16th passes with a 32nd clean up.
There was hand sanding needed afterwards. My question is will a power feed improve my results? Restated Are the blips and chatter marks that I am sanding out due to my inconsistent feed and pressure?
paduke is offline
post #4 of 5 (permalink) Old 08-02-2015, 08:55 AM
Bill, Your Triton should be powerful enough to make the cut in one or two passes and get better results. Power feeders on a router table is not a great idea because you must let the bit cool between passes anyways. With a feeder you would tend to rush this process resulting in shorter intervals between bit sharpening. Feeders are best left to shapers.
ksidwy and tomp913 like this.
post #5 of 5 (permalink) Old 08-02-2015, 11:41 AM
as for uniform feed rates PF will do that...
as for replacing feather boards, no..
peak hp vs. real hp danapointed New Member Introductions 15 05-10-2017 03:33 PM
Craftsman v. Delta Tablesaws Thowie70 Tools and Woodworking 22 02-24-2014 10:12 PM
Power Feed vs. Horizontal Table wbrisett Table-mounted Routing 4 01-03-2014 01:49 PM
Peak HP dgcutter General Routing 22 01-10-2013 08:23 PM
All about Power Tools iconlife Tools and Woodworking 10 08-13-2012 12:09 PM
