compression spiral bit - Router Forums
post #1 of 3 (permalink) Old 02-16-2008, 10:32 AM Thread Starter
Default compression spiral bit
good morning what is a compression spiral bit and what it used for. thanks rich1
rich1 is offline
post #2 of 3 (permalink) Old 02-16-2008, 11:06 AM
Hi rich1
Compression Up/Down Spiral Router Bit
This 2 flute solid carbide bit is needed to get clean, chip-free and splinter-free cuts in composite sheet goods such as Melamine or 2-sided Formica/Laminates and veneered plywood.
The Up-shear/Down-shear design of the bit cuts toward the center of the sheet from both sides at once, saving time and eliminating waste.
http://www.mlcswoodworking.com/shops...iral_up_anchor
post #3 of 3 (permalink) Old 02-16-2008, 01:30 PM Thread Starter
thanks bobj3
rich1 is offline
Spiral Bits/splinters George II General Routing 5 01-29-2008 10:50 AM
Spiral up or spiral down slumlord New Member Introductions 6 12-14-2007 12:54 AM
Compression spiral cutters Hamlin General Routing 4 02-03-2007 01:37 PM
spiral bit woodendigits Router Bits - Types and Usage 2 09-03-2006 11:15 PM
Sharpen a spiral bit fade2black Router Bits - Types and Usage 6 01-05-2006 11:04 AM
